Sponsored by: CARiD
Driver's side HID out
Old Mar 11, 2004 | 01:14 AM
Neil64's Avatar
Neil64
Exclamation Driver's side HID out
Tonight I noticed that my driver's sider HID light is not coming on. I am assuming that the OEM D2R is burnt out. I thought this would be a quick and relatively cheap repair. After checking out this forum, it seems that the D2R bulbs are outrageously expensive. As I can't afford to drive around on one light, I need to find a local replacement ASAP that is reasonably priced. If I am willing to stick to OEM type replacement, should I really replace both? By the way, I am assuming that my bulds are originals and I am happy with the color. Are the bulbs labled with brand and temp?
Could it be something other than the bulb? Is there a to check everything before replacing a buld that does no t need replacing?
Is there an article on bulb removal/installation?
Thanks..
Neil
Old Mar 11, 2004 | 01:40 AM
rominl's Avatar
rominl
exclusive matchup
well you still should replace both, otherwise the color would be off and it would look very awkward. a set of 6000k d2r philips is about 250 shipped, i think it's very reasonably priced already? i can only think you can get the 4100k for a bit cheaper
if you want you might want to check on ebay too
NEWONE1
Feb 21, 2018 03:05 PM
gbphoto
IS - 1st Gen (2001-2005)
Mar 10, 2015 06:11 PM
YoshRX300
RX - 1st Gen (1999-2003)
Apr 30, 2007 03:39 PM
GS4Me
Lighting
Jul 29, 2004 12:35 PM
