Sponsored by: CARiD
Any way to get fogs brighter without getting HIDs for theM?
Old Feb 27, 2004 | 12:14 PM
zmatrix's Avatar
zmatrix
Default Any way to get fogs brighter without getting HIDs for them?
HID fogs are too expensive of an upgrade at the moment so I was wondering if there was a way to get brighter lights from the fogs, something in between factory and the HID fogs in terms of brightness.
Old Feb 27, 2004 | 12:22 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
You can upgrade the bulbs.
Here's a pic comparing mine (black with Piaa) and Dex's old blue GS (with Silverstars) a couple years ago. Both definitely brigher than stock, the Piaas were definitely brigher than the Silverstars.
http://www.digitalsimple.com/The%20G...Comparison.htm
Also if you want more light you can go to clear
http://www.digitalsimple.com/The%20G...0Installed.htm
Old Feb 27, 2004 | 01:27 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
Something that Lexkhost suggested on another thread was using 9005 hi beam bulbs in there since they have no "cap" like a headlight bulb (that black thing on the top that limits output). Since they are so low, blinding oncoming drivers should not be an issue. He also stated that heat is not a issue either
Old Feb 27, 2004 | 04:51 PM
PAULGS430's Avatar
PAULGS430
Thumbs up ;)
What Dgot's said . You will have to perform surgery on the 9005 for them to fit tho.
Paul
Old Feb 27, 2004 | 05:12 PM
D2-AUTOSPORT
Former Sponsor
Default Re: ;)
Paul
really, are they too long, or is the base different?
Old Feb 27, 2004 | 06:20 PM
zmatrix's Avatar
zmatrix
wow I am feelin' it - so how much are we talking about for these bulbs?
Old Mar 3, 2004 | 09:36 PM
PAULGS430's Avatar
PAULGS430
Wink uh huh
YES- the base area will need to be shaved or clipped for perfect fitment. Just clip em or use needle nose pliers & cut em.
Paul
Old Mar 5, 2004 | 06:02 PM
Lexkost's Avatar
Lexkost
9006 and 9005 are the same physcal size :
Attached Thumbnails Any way to get fogs brighter without getting HIDs for theM?-9006_clear.jpg
Old Mar 5, 2004 | 06:04 PM
Lexkost's Avatar
Lexkost
And 9005
Attached Thumbnails Any way to get fogs brighter without getting HIDs for theM?-9005_clear.jpg
Old Mar 5, 2004 | 06:10 PM
Lexkost's Avatar
Lexkost
Default Re: uh huh
Paul
No cutting needed 9005 and 9006 are same base!
Old Mar 7, 2004 | 11:44 PM
bhandsome's Avatar
bhandsome
Question
what about if you have h7 and you want to put the high beams on will you still have to do mods and if so what do you need to cut
RXGS
53
Jan 22, 2011 05:48 PM
wolverine
Feb 9, 2010 02:49 PM
jonny2k
Jun 1, 2007 04:36 PM
dr_ed
Nov 17, 2002 03:45 PM
rominl
Jun 4, 2002 12:20 AM
