Sponsored by: CARiD
light problem
Old Feb 23, 2004 | 07:36 PM
JSC300's Avatar
JSC300
Default light problem
Hey, whats up...i have and this problem for the 2nd time now, i have sylvania silver star low beam lights in my 95 sc300 and when i hit the brake or use the power roof or anything electronic (turn signal etc...) at night when my lights are on the console (gauges and console and lights) will flicker or dim for a split second...i replaced my battery with a better one and got my electrical system looked at by a toyota tech...now the problem is back and im wondering if its the sylvania silver start lights that are causing this ...maybe they are sucking up too much amps of power??...any ideas?...im thinking about picking up an HID kit if i cant fix it. thanks
-Justin
Old Feb 24, 2004 | 08:40 AM
hwallen172's Avatar
hwallen172
I had the same problem, and I fixed mine by replacing the connector at the end of the negative battery cable and cleaning and tightening the end that goes to the engine block. From what I've read, it seems that the ground cable on the SC300s can be problematic. I've heard that some people have replaced the ground cable with one that's for the GS300 because the SC300 cable only comes as part of an assembly and is much more expensive. I even ordered the GS300 cable but never put it in because my repairs on the existing cable were successful. It looks like it would fit, however.
Old Feb 24, 2004 | 09:52 AM
97SC's Avatar
97SC
Either buy a grounding kit, or make your own. Ground at least the alternator and neg battery cable I resolved alot of my problems by buying a grounding kit...
Old Feb 24, 2004 | 10:10 AM
mikeloc24's Avatar
mikeloc24
Question electrical problem...
Seems just like what I'm dealing with now! I was hesitant to buy a new battery because our cars use the big international sized battery and I didn't want to drop the $110 at Sears unless I was POSITIVE it was the battery that was causing the problem. I had a mechanic check the grounds (supposedly) but he couldn't find a problem. Now I hear mention of a "grounding kit" and possibly changing the negative battery cable connector. I think I'll do that this weekend and see what happens, this is really a pain in the butt but I doubt it's the silverstars that are causing the problem. I have PIAA Super Whites in mine and it works just fine with no issues, like you said, the problem happens when I use anything electronic in the car. I haven't experimented with the sunroof yet as it's been raining in L.A. but I bet it would happen then too. Geez, where can I get one of these grounding kits and what cable would be best? The GS cable?
Old Feb 24, 2004 | 10:26 AM
97SC's Avatar
97SC
The grounding kit I purchased was from http://www.lexusgrill.com/ but you can make a kit yourself that at least takes care of the alternator and neg battery cable using amp power/ground wires and crimping on some ring terminals. I purchased my kit for a little over $100 from http://www.lexusgrill.com/ (includes 8 wires I believe, cut, soldered and shrinktubed) but the site seems to be down at the moment.
Old Feb 24, 2004 | 10:32 AM
mikeloc24's Avatar
mikeloc24
Smile
What all does the kit include? I'm gonna put together my own kit as I don't have a c-note at the moment to burn on a pre-packaged one...
Old Feb 24, 2004 | 10:39 AM
97SC's Avatar
97SC
It included two longer bolts, some washers, and 8 precut ring crimped soldered and shrink tubed cables. Just go out and pick up some amp wire and those gold or whatever ring terminals to fit it. Crimp them on and that should work out fine for you.
Old Feb 24, 2004 | 11:41 AM
JSC300's Avatar
JSC300
thanks for all the help, ill see if i can order one of those grounding kits...is there any other place you can get them other than the internet?
Old Feb 24, 2004 | 11:43 AM
97SC's Avatar
97SC
Not that I can think of(off the internet) But making one yourself as I mentioned is pretty easy and should take you less than an hour and about $15 tops depending on what wiring you use and what connectors. Good luck
Old Feb 24, 2004 | 01:06 PM
mikeloc24's Avatar
mikeloc24
Thumbs up
Thanks 97 SC, I'm gonna make my own kit and see what happens....what city are you in by the way? I'm in the LBC...
Old Feb 24, 2004 | 03:03 PM
97SC's Avatar
97SC
I'm in Newark, SF Bay area, right across from the Peninsula off 84. GTG, leaving work early, good luck One thing, you may want to solder your connections if you have time for reliability.
Old Feb 24, 2004 | 09:34 PM
JSC300's Avatar
JSC300
oh yeah i forgot to add that when im driving and i put the car in neutral...as soon as the RPM's hit 0 the lights flicker for a second too....weird...
Old Feb 25, 2004 | 09:30 AM
Nick T's Avatar
Nick T
JSC300,
Do the headlights also dim when you step on the brakes? I do not think it is your battery. It could be a loose or corroded cable. Most probably your alternator's regulator is bad. Pull the alternator and have your local parts store check. If everything is within spec, you should not have any dimming or flickers, putting on a grounding kit would only be a band-aid repair.
Regards
Old Feb 25, 2004 | 10:09 AM
PHML's Avatar
PHML
Master Thread Closer!!
Question -
Aren't grounding kits basically hyped-up, thick, insulated amp wires?
Old Feb 25, 2004 | 10:15 AM
97SC's Avatar
97SC
Originally posted by PHML
Question -
Yes, basicly. That's why I mentioned making one yourself.
Here's a small review on ground wires from an RSX tuner... http://www.ivtecdaily.com/rsx/mods/groundWires.html
