[OWI] 2006 GS window's not working!
Hello jesmarin85, this may help:
With ignition switch in the “ON” position, do the following:
1. If the power windows have not been initialized, the driver’s door power window switch should be blinking.
2. Push the driver’s door power window switch to open the window.
3. Pull up the driver’s door power window switch until the window closes, and hold it for approximately
one second. At this time, the driver’s door power window switch illumination changes from blinking
to constant illumination.
4. Repeat steps 1 – 3 for each door’s power window.
NOTE: When the battery terminal has been disconnected, pull up each door’s power window switch until the window closes, and hold it for approximately one second. At this time, each door’s power window
switch illumination changes from blinking to constant illumination.
5. Check for proper operation of the “one–touch open and close” function by fully pushing the switch “DOWN”
once and fully pulling the switch “UP” once.
