Just found out the IS250 I have had an aftermarket Flyaudio GPS unit in it. It's missing the nav disk and also has a odd climate control misreading. Anyone know where to get one? I tried car light trends who used to rep them and they no longer due. Thanks for the help.
The FlyAudio does not use a disc, its a SD card that should be under the "CARD" tab. open it up and see if there is an SD card. If not then you can get a iGO map SD card from ebay and insert it and then you will need to "point" the system to the new SD card. Hope that helps you out.
