Engine Noise through speakers...HELP!?!?
Old Jul 20, 2003 | 06:11 PM
UTGS400's Avatar
UTGS400
Default Engine Noise through speakers...HELP!?!?
I recently installed an entirely new system in my car and have not been able to get rid of the engine noise coming through the speakers. So far, I have run all new interconnects, re-run all the grounds, and double checked all the connections. What else would you recommend? Tomorrow I will be replacing the interconnects once again in hope that this will solve the problem.
Old Jul 20, 2003 | 07:40 PM
Gs3PoweR's Avatar
Gs3PoweR
do you have aftermarket mids and highs cuz if you dont i think thats the problem........i had the same problem and the noise gets louder the faster i drive......now that i change my stock speakers i dont hear it no more..........hope this help.
Old Jul 20, 2003 | 08:15 PM
al503's Avatar
al503
your interconnects are probably ok. You might be getting noise if you are running the interconnects next to the power wire though. If you are, try running them on the other side of the car.
Old Jul 21, 2003 | 08:42 AM
UTGS400's Avatar
UTGS400
Gs3PoweR- I replaced the entire factory system including mids and highs.
al503- I ran the interconnects on the passenger side of the car while the power wires were run on the drivers side, so that should be the problem. The interconnects I am using are supposed to be mid-high quility, but I found out that a few companies have had problems with these wires. I should have a twisted pair of interconnects in within the next few days, so I will let you know if that was the problem.
Wahlnutz
Dec 31, 2012 04:04 PM
TroySC300
18
Mar 3, 2012 10:45 PM
drstrangel
Nov 8, 2009 02:27 PM
APU6speed
Jun 30, 2003 10:58 AM
quadoptix
Apr 21, 2003 03:58 PM
