bass hitting when i start car
Old Jul 1, 2003 | 08:56 PM
PearlLex's Avatar
PearlLex
Question bass hitting when i start car
Hopefully someone here knows the answer. A few days ago we put in my 15" Eclipse + 500W Rockford amp in my car. It sounds really good, loud and clean. Whenever I start the car though, it LOUDLY hits bass for about 2 seconds until the car is started. Also, wheneever I turn the radio completely off, bass hits constantly BOOOOOOOOOOOOOOOOOOOOOOOM. Any ideas?
Old Jul 1, 2003 | 09:11 PM
snboarder8's Avatar
snboarder8
lol, i feel ya, i got the same problem bro. check out my thread.
system
Old Jul 1, 2003 | 09:58 PM
PearlLex's Avatar
PearlLex
thanks a lot...so where did you reground it to?
Old Jul 1, 2003 | 10:52 PM
meZoom!'s Avatar
meZoom!
Super Moderator
LOL guys.......
PearlLex...you put in a 15?!?!?!?! woah.....have fun shaking your trunk around!
good times.
Old Jul 1, 2003 | 10:55 PM
LexDiamond's Avatar
LexDiamond
I remember having that problem it was becuase the iddiots at tweeter didnt use remote turnon the for the amp I think they used the antenna
check that
Old Jul 1, 2003 | 11:36 PM
PearlLex's Avatar
PearlLex
Yea I'll go through and check a bunch of stuff. Yeah, I put in the 15". I used to have it in my Acura Integra with 4 gauge wire and it never sounded that great for a 15". I put it in the Lexus the other day with a Rockford 8 gauge wiring kit, and holy **** is it loud.
Old Jul 2, 2003 | 10:25 AM
snboarder8's Avatar
snboarder8
regrounding didn't solve any problems for me, i still get the loud BOOOOOOOOOOM if i turn off the radio. egainer suggested puttin a switch in that controls the amp, but i'm wonderin if there's anything besides that.
Old Jul 2, 2003 | 05:45 PM
LexDiamond's Avatar
LexDiamond
Check your remote turn on and your antenna ground thats what it was for me.
Old Jul 2, 2003 | 10:59 PM
snboarder8's Avatar
snboarder8
what do u mean about the antenna ground? the remote turn on comes from the stock radio. whenever i turn the radio off i get the loud BOOOOOOOM,
Old Jul 3, 2003 | 03:05 AM
LexDiamond's Avatar
LexDiamond
oh ok that means the rca's are backwards or the polarity on yours subs
Tweeter did that to me check it out....ignore the antenna comment
Old Jul 3, 2003 | 03:06 AM
LexDiamond's Avatar
LexDiamond
it vibrates constantly right and u gotta turn the stereo on real low to rid it correct?
(off the subs just shake like boooooooooom right?)
Old Jul 3, 2003 | 05:36 AM
PearlLex's Avatar
PearlLex
It doesn't matter how high or low i turn the bass or the volume, it hits loud constantly with the radio off
Old Jul 3, 2003 | 05:42 AM
LexDiamond's Avatar
LexDiamond
did you run your rcas and power wires down the same side?
Old Jul 3, 2003 | 06:36 AM
retrodrive's Avatar
retrodrive
Search Function Inc.
Wait, this has nothing to do with polarity or RCA's close to power wires. The only way that RCA's are consearned is if they are directional (should be marked with arrow); otherwise, it does not matter how you wire them. Also check your grounds. Regrounding helps this problem in most cases but not always. Don't forget the ground at the head unit; that one is the most important one in situations similar to yours.
This "pop" is usually the result of an amp turning on after the head unit does. What you can do is put a constant 12v on a turnon wire and put a switch on it. This way you can turn on your amps first and then turn on the headunit. Since now that HU and your amp are independent from each other, there should be no pop.
Old Jul 3, 2003 | 02:23 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Retro is right, but what we are talking about is oscillation. the amp is oscillating because it doesn't have an input signal, yet is powered up. the problem is ......
..... and that's is why your amp is staying on without an input signal and oscillating. You need to either purchase a component with a delay circut in it (*soft start technology) like an audio control x-over for instance, or you need to purchase an amp with soft start technology. Your third option is to chunk the factory head unit.
Either way, you will not get rid of this problem without spending a little cash unfortunately because your amp doesn't have SST and your radio is stock. So your amp will always power on immediately with the ignition and pop.
The radio needs to see full power FIRST and be ready before the amp lights up.
One thing that baffles me though, how long does the amp oscillate AFTER you turn the car/radio off? forever? or just until the ignition is off?
