Check here first ! For questions about your system.
Old Jun 23, 2003 | 07:09 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Default Check here first ! For questions about your system.
If you see your question here go to the links at the bottom relating to the section you are needing to view for the answer. I have spent many years in the car audio field and i personally know some of the folks that contributed to this FAQ. The best of the best have put together an all out full scale faq to answer almost anything you need to know about car audio.
Table of Contents
1 Definitions
1.1 What do all of those acronyms mean?
1.2 What is meant by "frequency response?"
1.3 What is a "soundstage?" What is an "image?"
1.4 What is meant by "anechoic?"
2 Electrical
2.1 My speakers make this high-pitched whine which matches the engine's RPMs. What is it, and how can I get rid of it?
2.1.1 Level 1: Check out the Amplifier(s)
2.1.2 Level 2: Reduce the System
2.1.3 Level 3: Move the Head Unit
2.1.4 Level 4: Testing the Car
2.1.5 Level 5: Adding Signal Processors
2.1.6 Level 6: Processor Isolation Tests
2.2 My system "pops" when I turn it off. What is happening and how can I get rid of it?
2.3 What is the best power wire to use?
2.4 What is the best speaker wire to use?
2.5 I heard that I should run my power wire directly to my car's battery. Why should I bother, and how do I do it?
2.6 Should I do the same thing with my ground wire, then?
2.7 Sometimes when I step out of my car, I get a really bad shock. What is wrong with my system?
2.8 When my car is running and I have the music turned up loud, my headlights dim with the music. Do I need a new battery or a new alternator?
2.9 What is a "stiffening capacitor", and how does it work?
2.10 Should I install one in my car? If so, how big should it be, and where do I get one?
2.11 What about adding a new battery? Or upgrading the amplifier?
3 Components
3.1 What do all of those specifications on speakers mean?
3.2 Are component/separates any better than fullrange or coaxials?
3.3 What are some good (and bad) brands of speakers?
3.4 What do all of those specifications on amplifiers mean?
3.5 What does "bridging an amp" mean?
3.5.1 Why should I bridge my amp?
3.5.2 Why shouldn't I bridge my amp?
3.5.3 What happens when an amp is bridged?
3.5.4 Does bridging an amp would halve the impedance of the speakers?
3.5.5 Can I bridge my 4 channel head unit?
3.6 What is "mixed-mono?" Can my amp do it?
3.7 What does "two ohm stable" mean? What is a "high-current" amplifier?
3.8 Should I buy a two or four (or more) channel amplifier?
3.9 What are some good (and bad) brands of amplifiers?
3.10 What is a crossover? Why would I need one?
3.11 Should I get an active or a passive crossover?
3.12 Should I buy an equalizer?
3.13 What are some good (and bad) brands of equalizers?
3.14 What do all of those specifications on tape deck head units mean?
3.15 What are features to look for in a tape deck?
3.16 What are some good (and bad) brands of tape decks?
3.17 What are features to look for in a CD head unit?
3.18 Should I buy a detachable faceplate or pullout CD player?
3.19 What are some good (and bad) brands of CD head units?
3.20 Can I use my portable CD player in my car? Won't it skip a lot?
3.21 What's that weird motor noise I get with my portable CD player?
3.22 What are some good (and bad) brands of portable CD players?
3.23 What's in store for car audio with respect to MD, DAT and DCC?
3.24 Are those FM modulator CD changers any good? What are my other options?
3.25 What kind of changer will work with my factory head unit?
3.26 What are some good (and bad) brands of CD changers?
3.27 Why do I need a center channel in my car, and how do I do it?
3.28 Should I buy a sound field processor?
3.29 What are some good (and bad) brands of signal processors?
3.30 I keep hearing that speakers for Company X are made by Company Y. What's the deal?
3.31 What is a Line Driver? Do I need one?
3.32 Can I play MP3 files in my car?
4 Subwoofers
4.1 What are "Thiele/Small parameters?"
4.2 How does speaker sensitivity affect real world SPL? Will a higher sensitivity give me a larger SPL?
4.3 What are the enclosure types available?
4.4 Which enclosure type is right for me?
4.4.1 Infinite Baffle ("free-air")
4.4.2 Sealed Box
4.4.3 Ported Box
4.4.4 Bandpass Box
4.5 How do I build an enclosure?
4.6 MDF for Dummies
4.6.1 What is MDF?
4.6.2 Where can I get MDF?
4.6.3 What type of saw blade works best when cutting MDF?
4.6.4 What type of router bits work well with MDF?
4.7 What driver should I use?
4.8 Is there any computer software available to help me choose an enclosure and a driver?
4.9 What is an "aperiodic membrane?"
4.10 Can I use my subs in the winter?
4.11 How can I carpet my enclosure?
4.12 Are large magnets always better than small magnets?
4.13 I know the box volume required for my subwoofer, but what are the best dimensions for my enclosure?
5 Installation
5.1 Where should I buy the components I want?
5.2 What mail-order companies are out there?
5.3 What tools should I have in order to do a good installation?
5.4 Where should I mount my speakers?
5.5 What is "rear fill", and how do I effectively use it?
5.6 How do I set the gains on my amp?
5.7 How do I select proper crossover points and slopes?
5.8 How do I flatten my system's frequency response curve?
5.9 How do I wire speakers "in series" and "in parallel?"
5.10 Are there any alternatives for Dynamat? It's too expensive!
5.11 How many devices can I attach to my remote turn-on lead?
5.12 How do I wire a relay in my system?
5.13 How do I design my own passive crossovers?
5.14 How do I build my own passive crossovers?
5.15 Can I split the single pre-amp output from my head unit to drive two amplifiers with a Y-cable?
5.16 How do I turn a stereo signal into a mono signal
5.17 How do I determine a speaker's polarity?
5.18 How can I use an oscilloscope to set the gains in my system?
5.19 Why are kickpanels such a popular location for mounting speakers?
5.20 How can I build custom kickpanels?
5.21 What's worse for a speaker, too much or too little power?
5.22 Why is distortion harmful to my speakers?
5.23 What tools do I need to cut Plexiglas?
5.24 Are there any other special requirements for working with Plexiglas?
6 Competition
6.1 What is IASCA, and how do I get involved?
6.2 What is USAC, and how do I get involved?
6.3 What are the competitions like?
6.4 Should I compete?
6.5 What class am I in?
6.6 Where can I find out when these Sound-Offs are?
6.7 How do I get sponsored by a manufacturer?
7 Literature
7.1 What magazines are good for car audio enthusiasts?
7.2 Are there any newsletters I can read?
7.3 What books can I read?
7.4 Can I contact any manufacturers on-line?
http://www.faqs.org/ftp/faqs/car-audio/
Old Jun 24, 2003 | 02:02 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
squish....
er,. ........ bump.
Old Jun 25, 2003 | 08:48 PM
AutoCoutureSC's Avatar
AutoCoutureSC
that's some great info! thanks!
Old Jun 25, 2003 | 08:55 PM
GaryDell's Avatar
GaryDell
I especially enjoyed reading section 3.5.4.
Old Jul 1, 2003 | 12:44 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
((cough))
Old Jul 1, 2003 | 03:04 PM
dmora's Avatar
dmora
Originally posted by onelasttry
((cough))
GOOD INFO Now if i can just find a nice looking double DIN MP3/CD/DVD player i will be in hog heaven.
Old May 27, 2004 | 07:56 AM
dknoxking's Avatar
dknoxking
Default Mute Signal at Inputs to Amp?
Trying to determine source of high-pitched whine. Under, "check the amplifier (2.1.1 Level 1)" you mention muting the signal at the inputs to the amp. How do I do this? It is a JL 300/4 amp powering front Dyno's and and sub. Thanks, David
Old May 10, 2006 | 07:28 PM
Tranceman's Avatar
Tranceman
amazing post. is this a sticky cuz if not it should be!
Old Mar 5, 2008 | 11:37 AM
handoverfi's Avatar
handoverfi
the link isnt working for me
Old Mar 5, 2008 | 09:20 PM
Neofate's Avatar
Neofate
CL Folding 10,000
Seems it has been restructured in parts. Start here:
http://www.faqs.org/faqs/car-audio/part1/
Old May 26, 2008 | 09:48 PM
saabkyle04's Avatar
saabkyle04
Hi, I was hoping you or someone else can give me some advice on what I need to do to set up an amplifier to an 07 ES350 with NAV!
I am adding a sub to my car and I am curious on the process that someone would go through to do this. I am going to add a 12" Rockford fosgate sub and a Kenwood amplifier. I am going to fun a remote cable for easy bass adjusting up to the driver's seat. The only problem is I don't know how someone would hook it up to the radio itself. I have the ML system with NAV and all I am doing is adding this sub to it, I'm not changing anything stock whatsoever. how would it work to have it hooked up? Would the volume on the sub be turned up with the radio volume? even though I have the bass remote and controls on the amp itself, will the sub's bass be increased when I increase the Stock system's bass?
What I am trying to say is that I want to control the bass of the stock and the sub separately, (remote vs. controls on the NAV system) but I want the volume of the sub to go up with the radio! Is this possible?
Thanks so much, I really appreciate it if someone can help me with this!
gregnorz
NX - 1st Gen (2015-2021)
Dec 20, 2018 01:55 PM
swfla
May 26, 2015 03:29 AM
PxH_83
Apr 25, 2007 09:05 AM
jyep
Aug 29, 2003 02:12 PM
Hameed
Apr 26, 2003 06:27 AM
