Antenna won't go down
Old May 26, 2003 | 06:49 PM
illson_2k's Avatar
illson_2k
Question Antenna won't go down
Has anyone had troubles with their antennas? Before I got a new deck I could push the antenna down after i turned the car off....now that I got a new deck it won't go down....anyone got any ideas
Old May 27, 2003 | 12:41 AM
meZoom!'s Avatar
meZoom!
Super Moderator
uhhh, before you got the aftermarket deck, you'd physically push the antenna down? or it'll go down automatically? is the antenna motor making any noise?
Old May 27, 2003 | 09:07 AM
angelslex's Avatar
angelslex
Default antenna
antenna
Hey guys Im pretty sure you can only change the antenna if you want it. and it will only cost you about $30.00.I have done it for a lots cars a lots of Toyotas Avalon,Camrys, Nissans altimas and maximas is a little tricky but u guys can do it first take out the old antenna out the base and then turn on radio so the antenna comes out and pull it out its going to look a metal piece with a white plastic piece that looks like teeth.then make sure that you unplug the power antenna at this point so that when you buy the new one u put it in and u plug the power back on it pulls it back into place . p.s make sure u open the bottom of the antenna "base"o you can take out the old and broken pieces
Old May 27, 2003 | 11:48 AM
illson_2k's Avatar
illson_2k
Before the aftermarket deck I would have to physically push it down and you could hear the motor.....but now I that I have the aftermrket deck it won't go when I push it and I don't hear anything
Old May 27, 2003 | 11:17 PM
skperformance's Avatar
skperformance
you did your wiring wrong for the ant
jasone36
Mar 22, 2025 03:49 PM
friarush
Apr 23, 2015 10:28 AM
RA40
22
Feb 29, 2004 05:19 PM
bberisford
Maintenance
Jun 16, 2003 10:45 AM
