hardwiring valentine one HELP!
Old May 2, 2003 | 11:22 PM
LeXGs43Rx3's Avatar
LeXGs43Rx3
Default hardwiring valentine one HELP!
I cannot understand what I am doing wrong with hardwiring my V1! I took off the console where the map light and the homelink is. I have the black wire from the V1 direct wiring kit underneath one of the two screws that are most visible after removing the kit, and I have tried connecting the red wire from the v1 with the blue plastic thing to the yellow, black, and red wires coming from the rear view mirror, but nothing!!! I started the car to test it out, but its not working! My V1 is fine, as I have tested it out with the cigerrete lighter and it works fine in there. Does anyone have any insight at all to this? Please help.
Old May 3, 2003 | 10:12 AM
LeXGs43Rx3's Avatar
LeXGs43Rx3
UPDATE...
I can get the V1 hard wire to work fine if I hook up the red wire on the V1 to the red wire from the homelink system, but when I try to hook it up to the red wire from the rearview mirror, it doesnt work! Anyone have ANY help? I want my V1 to go off as my car does so I don't kill the battery by mistake. Thanks!
Old May 3, 2003 | 12:27 PM
DPGS430's Avatar
DPGS430
Go and get yourself a 12 volt test light from your local auto parts store. You want to tap into a 12 volt power source that is switchable (only on when key is on).
Jim
Old May 3, 2003 | 02:11 PM
LeXGs43Rx3's Avatar
LeXGs43Rx3
Default thanks
Hey, i got some stuff from radio shack. I am just waiting for my dad to get home so I can try installing it again. Depending on how much time I have, I will try to make a full tuturial on this (I have noticed the others are incomplete, or confusing).
Old May 3, 2003 | 03:29 PM
DPGS430's Avatar
DPGS430
Actually, there are only 4 screws holding up the upper console. 2 behind the square plate under the lexus link for the garage opener and 2 under the dome lights. Once you get them off, the whole upper console comes off.
Jim
Old May 3, 2003 | 05:22 PM
tomtnc's Avatar
tomtnc
Follow the detailed directions I posted in this thread:
V1 Hardwire Instrucitons
Old May 3, 2003 | 09:47 PM
LeXGs43Rx3's Avatar
LeXGs43Rx3
I just cant figure out out of the 4 wires coming from the rear view mirror, which one do I use?
ESdoesit
Apr 17, 2018 07:27 PM
socaligs
Jan 9, 2017 09:02 PM
powderbrak
Jan 15, 2014 06:40 AM
costanza
Apr 18, 2013 10:01 AM
RXGS
Jan 29, 2011 09:54 PM
