Volume problem
Old Feb 16, 2003 | 02:31 AM
wim's Avatar
wim
Angry Volume problem
Hi,
When I am riding and I put my lights on or use brake my radio volume sounds louder. Does anyone know what this is?
Old Feb 16, 2003 | 03:10 AM
retrodrive's Avatar
retrodrive
Search Function Inc.
Possibly an alternator. Are you sure that it gets louder as you use up more opwer. The usual case is when you activate your powerbrakes and it drains power out of your electrical system and alternator is too weak. This MAY make sound quieter (although not likely).
Old Feb 16, 2003 | 05:06 AM
wim's Avatar
wim
Thanks for your reaction. First the radio sounds quieter and then it sounds much louder and after that normal. By the way, what is a altanator a don't know the Englisch word can you explain it.
Old Feb 16, 2003 | 12:35 PM
retrodrive's Avatar
retrodrive
Alternator is a unit that is spun by the engine to produce energy that keeps your battery charged. Some countries call it dynamo-machine and some call it generator. First I would suggest getting the battery out of your car and charge it with low rate amperage (make sure you switch your charger to like 2 amps) to rejuvenate it to the original condition. It should do it overnight. Put the battery in and see if it helps the problem. Probably what happens is that your battery is weak (alternator weaken batteries with time due to its constant high amp charging) so when you powerbrake and draw power from battery (music gets quieter), alternator kicks in to charge it and you get more electrical flow then your system needs (music gets louder). As a last resort you need to check out the power regulator in your car. The Lexus ones are very slow (that’s why we get dimming in headlights easily) and it can get even slower with time. Basically it might not be able to keep power constant when there are variations in amp flow from your alternator. All these things you need to discuss with a mechanic who is trying to fix your car and not rip you off. These are just some specific things to check out. Good luck.
Old Feb 16, 2003 | 02:08 PM
fierce gs's Avatar
fierce gs
hey retrodrive...
Could you give more info on our power regulators?
I always thought the car dimmed a bit too easily. Is there anyway to tweak the power regulator or switch it out?
thanks.
Old Feb 16, 2003 | 06:28 PM
retrodrive's Avatar
retrodrive
No, there is no way to tweak your curreent one. You can bypass it with am external aftermarket one that works faster.
Old Feb 17, 2003 | 01:29 AM
fierce gs's Avatar
fierce gs
Do you think its something that I should mess with? How much would it cost, and would I be able to install it myself?
Old Feb 17, 2003 | 02:14 PM
wim's Avatar
wim
Hi Retrodrive,
Thanks for your advice. I only have the problem when i am driving a big distance. Yesterday I charged my battery and everthing seems to be normal today. So i hope the problem is solved, I let you know.
By Wim
Old Feb 17, 2003 | 05:47 PM
retrodrive's Avatar
retrodrive
Try charging your old one on slow charge of 2 amps. Looks like your battery just got weaker with time.
scENFORCER
Jul 7, 2011 03:17 PM
kwikrnu
13
Dec 19, 2007 10:57 PM
GeneralD
Oct 31, 2007 10:02 PM
Brencent
Oct 3, 2007 03:22 PM
Vmoney
GS - 1st Gen (1993-1997)
Aug 3, 2006 10:15 AM
