Lexus Remote & Transponder Key Programming Instructions Most Models
Old Dec 25, 2013 | 09:02 PM
username32's Avatar
username32
Default Lexus Remote & Transponder Key Programming Instructions Most Models
I don't know if someone else has posted this but I thought I throw this in here since it might help someone else aside from me looking to save some bucks avoiding the dreaded dealer visit.
LEXUS TRANSPONDER KEY PROGRAMMING TYPE A B C D E
ES300
1998 TYPE A
1999 TYPE A
2000 TYPE B
2001 TYPE B
2002 TYPE C
2003 TYPE C
ES330
2004 TYPE D
2005 TYPE D
2006 TYPE D
GS300
1998 TYPE B
1999 TYPE B
2000 TYPE B
2001 TYPE B
2002 TYPE B
2003 TYPE B
2004 TYPE B
GS400
1998 TYPE B
1999 TYPE B
2000 TYPE B
GS430
2001 TYPE B
2002 TYPE B
2003 TYPE B
2004 TYPE B
GX470
2003 TYPE D
2004 TYPE D
IS300
2001 TYPE B
2002 TYPE B
2003 TYPE B
2004 TYPE B
LS400
1997
1998 TYPE B
1999 TYPE B
2000 TYPE B
LS430
2001 TYPE E
2002 TYPE E
2003 TYPE E
2004 TYPE D
LX470
1998 TYPE B
1999 TYPE B
2000 TYPE B
2001 TYPE B
2002 TYPE B
2003 TYPE D
2004 TYPE D
RX300
1999 TYPE B
2000 TYPE B
2001 TYPE B
2002 TYPE B
2003 TYPE B
RX330
2004 TYPE D
2005 TYPE D
SC300
1998 TYPE B
1999 TYPE B
2000 TYPE B
SC400
1998 TYPE B
1999 TYPE B
2000 TYPE B
SC430
2002 TYPE E
2003 TYPE E
2004 TYPE E
TYPE A
1998-1999 ES300 Key Programming
Key Programming 1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your
key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key.
If you have a master key then you will probably need to perform this procedure more quickly.
TYPE B
Lexus Key and Remote Programming
Remote Programming 1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove. Do not turn it on.
3. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
4. Close and open drivers door.
5. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock,Lock, Unlock, Lock, Unlock)
6. Put key into ignition. Turn to "ON" , turn off and remove.
7. You will see the door locks cycle by themselves.
If the door locks do not cycle (lock and unlock) by themselves then the car isn’t in programming mode and you must start over.
8. On the remote, press and hold the LOCK and the UNLOCK button at the same time for no more than 2 seconds.
9. On the remote, press the LOCK button for no more than 1 second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted.
IF the locks cycle twice it has failed.
The most common reason for programming failure is because the car didn’t receive a good signal from the remote. To fix this problem try these tips. 1) Stand outside of the car while you are performing steps 8 and 9. 2) Don’t hold the remote buttons down as long.
As long as the car is still in programming mode you can keep trying steps 8 and 9 until you complete the programming. If you wait too long and the car exits the programming mode then you must start over.
After you get the remote to program then continue on with step 10.
10. Close and open door to end programming procedure.
TYPE C
Lexus Key and Remote Programming Instructions
Key Programming
Remote Programming
2. Put key into ignition and remove TWO TIMES.
3. Close and open the drivers door TWO TIMES.
4. Put key into the ignition and remove.
5. Close and open the drivers door two times.
6. Put key into the ignition. Close the drivers door.
7. Turn ignition ON then OFF ONE TIME- this will put the car in ADD mode for your remote. (Turning
the ignition ON then OFF TWO TIMES will ADD the remote but will erase all existing remotes.)
8. Remove the key from the ignition. The door locks will cycle one time (or two if you are erasing) .
On the REMOTE press and hold the LOCK and the UNLOCK button for 2 seconds. On the REMOTE press the LOCK button for one second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted. IF the locks cycle twice it has failed. IF this happens you must start over. Hold the remotes higher up for better reception
9. Open and close the drivers door. Put key in ignition and pull out. This will end programming.
TYPE D
Key Programming
You can not program this key yourself. You will need to take your car and key to either the dealer or to a local locksmith that has the Lexus programming software
TYPE E
Key Programming
1. Close all doors.
2. Insert an already programmed master key into the ignition.
3. Turn the key in the ignition ON and OFF FIVE (5) times.
4. Open and close the drivers door SIX (6) times.
5. Remove the key from the ignition.
6. Insert the new key you want to program into the ignition.
7. Wait up to 2 minutes. The security light will be blinking for up to 2 minutes. When it stops blinking your key is programmed. To end programming step on the brake one time.
NOTE: You have 35 seconds to complete steps 1-5 and 10 seconds to complete step 6. If you do not do this procedure fast enough the car will not go into programming mode and your key will not program.
If the security light does not go out after 2 minutes start the procedure over again.
Erase Key Procedure
If you need to erase existing keys, in the case of stolen or missing keys, follow the procedure below. This will erase all keys except for the master key you use during this procedure.
1. Close all doors.
3. Turn the key in the ignition ON and OFF SIX (6) times.
4. Open and close the drivers door SEVEN (7) times.
I recommend doing this procedure a couple of times to make sure it takes.
Remote Programming
7. Turn ignition ON then OFF ONE TIME- this will put the car in ADD mode for your remote. (Turning the ignition ON then OFF TWO TIMES will ADD the remote but will erase all existing remotes.)
8. Remove the key from the ignition. The door locks will cycle one time (or two if you are erasing) . On the REMOTE press and hold the LOCK and the UNLOCK button for 2 seconds. On the REMOTE press the LOCK button for one second.
Old May 26, 2016 | 01:28 PM
qupid10's Avatar
qupid10
I drive a 1997 ls400 and the master key seems to be worn down from me using it so much on a daily basis. I have a spare key that the previous owner have me and I wanted to program it to my car so it'll start. My question is, is there no way to program the 1997 year model LS 400?
ikovalchuk
General Classifieds
Apr 5, 2010 09:37 AM
kozmo
General Classifieds
Jul 7, 2009 05:40 PM
joshlee78
IS - 1st Gen (2001-2005)
22
Aug 3, 2004 07:27 PM
mongrel
RX - 1st Gen (1999-2003)
Dec 18, 2002 11:26 AM
