The amp and speakers sound great when they are working, but drown out the highs and mids. Im trying to turn the bass gain down to acheive a happy medium.
The problem is, the signal from the LC2i is fading on and off. I look at the box itself, and the power light is coming on and off. I have everything wired coorectly as I can see. The constant power, remote, sub input from the stock subwoofer.
where are u getting audio input signal from to the LC2i? try using a full range signal ilke the door speakers instead of the sub.. because the sub signal isnt a constant signal.. it comes on an off as needed..which is why the LC2i turns on an off.. or u could try turning off the GTO an run a remote turn on signal from ign.. but it would be easier to goto these wires at the factory amp..The amplifier is in the right side of the luggage compartment.
Left Front Speaker (+/-) white - red (low) amplifier, wht 10 pin plug, pins 4, 10
Right Front Speaker (+/-) brown - pink (low) amplifier, wht 10 pin plug, pins 1, 5
