Quick Question
Old Oct 13, 2002 | 07:37 PM
Jazziz's Avatar
Jazziz
Question Quick Question
I'm trying to find an online source to get 3/8" spacer rings for my Dyn install. I've found 1" ones and debating whether I will cut them in half and planing them down. Thanx.
Old Oct 14, 2002 | 12:42 AM
LS007's Avatar
LS007
I ended up using 1" spacers for my Dynaudio 240 MKII in my LS430. The factory spacer had about 1" depth, so I wanted to keep it the same.
I did try the Toyota Echo/Avalon spacer at www.autotoys.com that will fit the Lexus with the exact same 3 screw hole configuration, but it wouldn't fit the Dynaudio MW170 7" driver. So, I stuck with the generic 1" spacer and sandwiched it againt the doors sheet metal with 1" flat washers and dynamat. The outside diameter of the generic spacers is just a little smaller than the metal opening on the LS430 (the flat washers are manditory).
www.autotoys.com does have 1/2"spacers.
KING
Feb 26, 2016 08:09 PM
KING
VIP Style
Feb 26, 2016 05:25 PM
mdgrwl
Feb 17, 2009 08:48 PM
sincityIS
Suspension and Brakes
12
Feb 19, 2008 04:33 PM
