I am in the process of hardwiring my Valentine One but ran into a problem.
I've been looking online for a switched source and wasn't able to find anything on my 98 LS so I decided to go with the red wire coming out of the garage door opener. I then grounded to a screw but nada. Tried the connection a couple of times to avail. I ran out of time and had to button it back up.
Was my ground off? I wish I had taken some pictures but had very little lighting.
Here is my reference post.
https://www.clublexus.com/forums/lex...-question.html
Thanks, Ed
Thanks, Ed
To be honest I never use any "random" switched output, especially one up in the headliner area. The fuse rating for those circuits tends to be low plus without the entire electrical system schematic I have no way of knowing what the load rating is.
I would run a wire through the headliner, down the a-pillar and to the ignition switch harness. There I would grab switched power from Ignition 2. This way the radar powers on only when the car is running but will not be on if you have the radio on while in the Accessory position.
why not tie into the cig lighter wire? its fused at the fuse box if any probs arise...
garage door opener isnt switched. it's always hot. the sunroof power on the other hand....
Quote:
Do you know which wire on the moonroof switch I could use?Originally Posted by PureDrifter
try buying a $5 test light an probe the interior fuse box... turning the key off & an on til u find the proper (fused) wire to use... or i for see big problems in ur future other than a speeding ticket.
