need help quik
Old Sep 9, 2002 | 01:34 AM
dj_kow's Avatar
dj_kow
Unhappy need help quik
i took out a amp to replace it with a different one then when i hooked up the new one there was no power and then i tried to hook up the old on to go back to how i had it and it had no power either, what went wrong? blown fuse? is the amp that i was testing blown?
i did not disconnect the battery btw
Old Sep 9, 2002 | 01:38 AM
j2tha0e's Avatar
j2tha0e
go to radioshack and get one of those $9.99 multi-meters. check several points to see if you got voltage. could be a number of factors.
first thing i would check are the fuses.
Old Sep 9, 2002 | 02:48 AM
DJ SprinklesNJO's Avatar
DJ SprinklesNJO
check ur ground, even if it is connected, it might not be a sufficient ground
Michael
38
Dec 15, 2014 04:35 AM
mtparker18
May 13, 2010 04:47 AM
gs300_94
Jul 2, 2009 02:56 AM
Aristo94
Jan 30, 2007 11:45 PM
johnj0286
Feb 23, 2006 09:59 AM
