No Power for power antenna
Old Aug 20, 2002 | 02:48 AM
NucLex's Avatar
NucLex
Angry No Power for power antenna
95 SC 400 Nacamachi
I went through the antenna mast replacement, now I can't get the antenna motor to work.
The toothed plastic antenna drive "rack"was broken in two, so I had to remove the whole assy, to remove the bottom section. I cleaned all the moving parts, checked the electrical connections & grounds, everything appeared servicable. I reassembled the antenna (in the car) mast in "down position". Turned on the ignition and radio (AM) waited 15 seconds for antenna to move up (I could hear a clicking sound in the speakers, but no antenna motor) then turned the radio off. I cycled it a few more times, no response.
I removed the (2) motor housing screws, carefully lifted the housing off and raised the armature enough to release the drive gear. I slowly pulled the mast to the full up position and reassembled the motor housing (ensured brushes were clean and made contact w/armature). Re-tried power on radio check......NOTHING!
Are there limit switches I need to set?
Any ideas from you electrical/audio types out there?
Thanks in advance for your help.
Old Aug 22, 2002 | 02:12 AM
strongsail's Avatar
strongsail
I remember reading another post about a ground lead that comes out of the housing and attaches to one of the screws that holds the unit to the fender - - did you re-attach the ground lead in the same place it was at before? To a clean, unpainted surface? Just a thought - -
friarush
Apr 23, 2015 10:28 AM
kid2rocks
GS - 1st Gen (1993-1997)
Sep 18, 2009 07:24 AM
bezee
Jan 22, 2005 10:47 PM
1stLexus
Apr 14, 2001 12:06 PM
