Do I need to upgrade my alternator?
You can go to Youtube and type in the Big 3 and you will get a very good video on how to do it.
Make sure you buy good wire and good connections. When it come to high end stereos you can go cheap on the hardware; that is just important. What good is the house on the mountain if you don't have a good road to access it? Use Memphis Audio wire; that is the best wire out there and Kicker is just a step down. Both companies still use copper in their wire. 1/0 gauge wire is about the best you can get.
Don't put a bigger pulley on your stock alt...you will burn it up quick. If you have a place near by to get a 200 amp that's awesome. I had to wait 3 weeks for mine to come in.
Big Mack
Thanks for the correction...I meant a smaller pulley.
Looking again at the amps installed here...these are AB amps meaing the pull raw power. The 500.1 pulls 50 amps alone. The beefed up alternator is the way to go. I use to own these amps and they pull a tremendous amount of current and the more you crank it up the more amps it pulls.
The big three on youtube is generic for any car.
I know you did, and you're welcome.
Gotta do the big 3 first. I can't agree to upgrading the alt immediately if relying on the stock wiring and only dimming/fluctuating at idle. If he were dropping it at speed, I'd agree right off, but let's see what the least expensive yet still necessary step does first.
Helpful to a point, but specific app would be mo betta.
Big Mack
Big Mack
TRENTIMUS
GS - 1st Gen (1993-1997)
Jan 31, 2019 03:41 PM
scENFORCER
Jul 7, 2011 03:17 PM
