2gs stock sub question, can anyone help
Old Sep 22, 2010 | 05:10 PM
kpyangz's Avatar
kpyangz
Default 2gs stock sub question, can anyone help
can i directly replace any aftermarket 10" sub and add an amp for the stock one?? and will it sound good/ worth doing? anything will help thanks
Old Sep 23, 2010 | 05:02 AM
maximus54's Avatar
maximus54
I think what your trying to ask is if you can replace the stock 10" with any aftermarket 10" sub. No, you cannot. Most aftermarket subs require an enclosure, and the stock sub is a "free air" sub. The best sound quality will come from a sub in an enclosure. Second, you will have to run a separate amp for the sub.
Old Sep 23, 2010 | 06:14 AM
milellie11's Avatar
milellie11
You can. I had the Mark Levinson sub on my 2GS replaced with a JL Audio 10IB4 sub. It is 8 ohms and is a free air sub. It was a direct drop in the stock location replacement with no aftermarket amp needed and it sounds great A few others have done this and have been very happy with the results.
Unfortunately, the JL Audio 10IB4 sub was discontinued. But it was replaced by the JL 10w1v2 8 ohm.
Check this thread for further info. Especially post number 52
https://www.clublexus.com/forums/gs-...placement.html
And here is a link to the 8 ohm sub brand new on Ebay, it's only $99! Remember, it's the 8 ohm that will work, not the 4 ohm version they make.
http://cgi.ebay.com/NEW-JL-AUDIO-10W...item4cf13004a9
Old Sep 23, 2010 | 01:22 PM
ErseOne's Avatar
ErseOne
If non ML, i believe you can. Check out http://www.edesignaudio.com/index.php?cPath=1_78_117
i think you can fit a 10" marine sub with an amp as well since they are IB.
Old Sep 23, 2010 | 02:39 PM
kpyangz's Avatar
kpyangz
thanks...i was wondering if i can put a jlw6 10" or a alpine type r 10" in? plus run an after market amp
Old Sep 23, 2010 | 06:11 PM
GSteg's Avatar
GSteg
The W6 and Alpine Type R will most likely not work in the stock location. Those subwoofers are not meant to be used in an infinite baffle setup unless you have a few of them.
Old Sep 24, 2010 | 10:54 AM
kpyangz's Avatar
kpyangz
oh, ok thanks anyways you guys i think ima just get a regular box then
AliGS300
Jan 13, 2010 09:36 AM
mikepae
Sep 7, 2006 12:26 PM
Shnerez420
Aug 12, 2005 09:32 AM
beez43
Feb 2, 2005 05:13 PM
