2nd gen gs3/400 firewall power wire
Old May 13, 2010 | 03:34 PM
toy4life86's Avatar
toy4life86
Default 2nd gen gs3/400 firewall power wire
for the self installers where did you guys run the power wire from the battery to the trunk? pics help
Old May 13, 2010 | 03:38 PM
rgarjr's Avatar
rgarjr
There is a rubber boot on the passenger side of the firewall, run it thru there. Remove the passenger side kick panel to fish.
Old May 13, 2010 | 10:16 PM
Kyle Harty's Avatar
Kyle Harty
I ran mine through that grommet on the passenger side mentioned above, it's easier if you remove the battery, the grommet is just to the left of the battery. Comes out high in the kickpanel. I got 0 gauge through there with some work, much easier with 2 people, one to feed from above and another to guide the wire coming through below.
Old Jun 4, 2010 | 08:45 PM
jcastaneda's Avatar
jcastaneda
I drilled just above the rubber grommet and ran a 1/0 gauge. If you do this ensure you put a rubber gromment in to prevent the wire from chaffing and grounding out your system. I removed the factory amp altogether to help make room.
westopill
Sep 9, 2019 05:25 AM
JemmyTran
May 12, 2012 09:16 PM
roasted
May 1, 2012 09:13 AM
Crzyxcrys
Jan 3, 2012 11:34 AM
graphX250
Jun 16, 2010 08:40 PM
