mcintosh amps
Old Jun 1, 2002 | 08:52 PM
Erick G's Avatar
Erick G
Default mcintosh amps
hey guys
any idea which mcintosh amps i would need to run this following setup
a/d/s 2way front stage
eclipse center channel
a/d/s rear fill
and a set of a/d/s coax in the trunk
my current helix amps are getting extremely hot and often shut off after longplay
also caused my fiberglass amp rack to crack
thanks again
Erick G
Old Jun 2, 2002 | 04:18 PM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
Are these seperates or coaxials? Also, are you planning on seperate amplification for EACH driver?
Percy
Old Jun 2, 2002 | 09:23 PM
Erick G's Avatar
Erick G
front stage is seperates
rear fill is coax
trunk is coax
center channel is coax
right now i have front stage bi amped
not sure how different sounding it would be seperate or not
thanks
Erick G
Old Jun 3, 2002 | 06:10 AM
Percy's Avatar
Percy
25 Year Member
Since the front stage is bi amped (and since it's a 2 way component set), I'd recommend the MCC404 6 channel amp so you can run the components and the rear fill.
For the center channel and the trunk, all you would need is a 4 channel amp. Mc has some that are configurable between 4, 3 and 2 channel, though I forgot the model number.
More info on Mc http://www.mcintoshlabs.com
Percy
Old Oct 3, 2002 | 04:10 PM
Hypermagic's Avatar
Hypermagic
Default mcintosh
I have MC440 from my previous car. (4*50 and 2*100)
I am having my stereo set up next weekend and probably need extra amps like yours since the nubmer of fronts - rears - subs speakers are more than my amp channels.
the biggest car amp from mcintosh is MC4000M (4*100 and 2*300). I guess you can run with both 6 channel(mc440/446) and 4 channel (mc427).
Keep us updated with you system
Old Oct 8, 2002 | 10:29 AM
Japanimal's Avatar
Japanimal
If your'e interested I have a McIntosh Mc4100 4x100 amp for sale. It was used for two months to power a set of Dynaudio 10in Subs in a sealed custom enclousure. I also have a Mcintosh head unit for sale.
mikobangz
Mar 25, 2014 08:45 PM
johnball
May 10, 2008 06:22 PM
LBC
Jun 27, 2006 06:32 PM
bso
Aug 4, 2004 10:45 AM
CoreY2K1
12
Jun 11, 2001 11:25 PM
