AMP just blew?
Old Jan 10, 2010 | 03:50 PM
kevin.tran's Avatar
kevin.tran
Default AMP just blew?
Last night I was listening to the radio at a very low volume and next thing you know it stopped. I check all fuses and the inline fuse from the power wire blew. So I replaced it turned on the radio again heard something from the subs and no more sounds. I checked the connections for the sub amp and mid amp everythings fine. I disconnected the power wire from the sub amp, replaced the fuse and now my mids are working and the fuse ain't blown anymore. So what do you guys thing? A blown amp?
Old Jan 10, 2010 | 05:35 PM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
Take an ohm meter to your subs - be sure to disconnect any other wires going into it or you'll get a bad reading. Also you may have to bench test your amp to see if it's still kicking.
Lex Luga
15
Aug 20, 2011 12:00 PM
noyz25
May 25, 2011 04:04 PM
leany
Mar 29, 2005 08:14 AM
TIKTIK11
Feb 5, 2002 09:47 PM
