Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#302
Sweet write up. I just got an SC300 that already has an aftermarket head unit with extremely bad alternator whine. Planning on doing this soon hoping to get rid of that.
#304
#306
Edit: Never mind. I think I can leave both unhooked and still get power to the sub amp by splicing the wire described under "Subwoofer for all sources" since the wire you are using to supply power is an ACC power wire
#307
Didn't work. I'm going to ditch the aftermarket harness and try to wire it up like you did. I do have a few more questions though. I noticed you didn't use a remote power wire, you only used the antenna wire. Although some cd players have both, mine does not. Is that why you wired two wires on the car to the antenna wire on the cd player harness? Is this also why you noticed that the sub amp is only powered on while the antenna is up? I never use the radio and my antenna stays up while the head unit is on, even if I'm using a different source. I don't want to hook up the power antenna, I would rather leave the antenna down. So what do these two wires do? Do they both go to the antenna, or is one of these wires the power wire to the sub amp? If I don't wire up the power antenna, will I still be able to rewire the plug for the sub amp like you did and get power to the sub amp?
#308
One last question. I connected my sub wires as described above, D1 (black) to positive and D5 (white) to negative, but your picture is opposite. The wire with the white stripe is the negative wire. Which is correct? My sub isn't working, and I'm trying to figure out if I did something wrong or if it just doesn't work.
#309
HOWEVER - switching D1 and D5 back and forth would have nothing to do with the sub working or not - it would just affect the phase of the signal sent to the OEM sub amp.
#310
D1 to positive, D5 to negative. Don't pay attention too much to the stripe - which, now that I noticed, is backwards - which explains why my system sounds a tad better with the sub in reverse phase on the head unit LOL
#314
I feel like the bass produced by the front speakers is felt through the sub, so when you said to lightly feel the sub with my fingertips, I did, and the sub felt like it was just "vibrating" with the bass of the other speakers instead of the bass produced by the sub itself.
#315
