Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#184
Ok well I have a 95 sc400 with the Nak system. I'm thinking that I'll just be running the speakers from the radio itself and use the sub amp to run the sub. All of my speakers work with the metra kit, except for my rears (which I replaced, and they didnt work with the stock system OR with the new system.) My sub barely works and I need to crank it way up to get it loud. So to get total use of my aftermarket unit, should I just run the wires straight up? I want to hear my stereo!
#185
Remember, the OEM head unit and OEM amplifiers are separate - so to get to the main speakers without rewiring the doors etc. you'd have to be able to connect to the OEM speaker wires after the OEM amp (bypass), or you'll probably hear nothing, or very little.
#186
sorry for the late feedback the write up worked perfect did everything set by set only problem is i didn't want to run short of wires so i ran to much and now have a little nest of wires in the trunk since i was to tired to cut them down to size.
i'll call that leaving work to do when i get bored..
thanks raine
thanks raine
#189
hi first off this thread is awesome worked for my friends sc400 w/o a nakamichi system. Question i have is that i got the speakers etc everything working except that he has a stock sub but no sub amp in the rear deck is there anyway around this? BTW the aftermarket apline radio i didnt see a RCA out plug like in your picture instead i have 4 holes 2 red 2 white in my apline..
#190
About your Alpine, I'm gonna guess that those red/white "holes" are the RCAs. Check the Alpine wiring diagram, it should say RCA.
The Kenwood I have used a separate harness for the RCAs, but essentially it's the same thing.
#191
yea i looked it up kinda figured it out but still about the the subwoofer amp located in the rear deck on the right side of the rear speaker the one you have to splice the wires in. He doesnt have one how can i get around that?
#193
i figured thanks guess he wont be having a sub woofer then. Its just weird how it has a sub but no sub amp i dunno if it was ever working but it was connected red and a black wire pretty thick too.
