I don't mean the sock catching fire by the sub, I mean near the wiring hireness for the third brakelight!
Same issue - if the wiring is getting hot enough to catch a sock on fire, it would burn through the housing since it is made of plastic, and could catch the rest of the car on fire. I still wouldn't use a sock, but it should be fine if you want to take that route.
you can PROBABLY remove the housing of the brake light and the brake light may still work fine. it might look funny but better than a towel. orrr, you can remove the third brake light all together. you dont need it...
