2002 GS Headunit help
Old May 16, 2009 | 11:57 AM
Beetle's Avatar
Beetle
Default 2002 GS Headunit help
I am Beete, an installer for Zen Motors, I have been in the industry for 6 years. I am looking for some help with a GS factory amp integration. The customer would rather not bypass the amp, loose the factory sub.
Metra recomends the TYTO-01, when that didn't work I tried the 70-8113. both harness have remote turn on but there is not a pin in the factory harness at that location.
There are two wires in the middle of the factory harness with 2.4v on each, i am thinking a data bus connection.
The funny thing is that when i first install the aftermarket radio, using the 8113, I can get it to play for about two minutes with only the front RCAs plugged in. Plugging in one of the rear RCAs shorts that side o the car. Then after two minutes the system dies. If I plug the factory radio in for a few minutes, then swap in the after market, I get another 2 minutes.
Am I doomed to an amp bypass or is there a trick? Tried searching no luck.
liolikas28
Nov 5, 2016 09:21 PM
Benitsubas
RX - 1st Gen (1999-2003)
Dec 11, 2014 08:31 AM
redbarron
Jun 18, 2011 08:23 AM
SC400-PHAE
Dec 13, 2010 06:07 PM
GSFREAK74
Mar 17, 2007 12:22 PM
