Help needed, Switch bypass for Destination
I have a 06 LX470 with generation 4 navigation unit. I have given up on making the hybrid DVD with 5.1 & 8.1 map versions after several failed attempts. I haven't seen where anyone else has been successful with this combination on the Gen 4 and 8.1. If I'm wrong, please let me know.
I have the Ultimate Lockpick 1 installed and it works great with the 5.1 but will not work with the 8.1 version. The blue tooth and he DVD bypass will still work, but not the destination bypass. So I would like to install a switch in the SPD wire and bypass the Destination. The tech from coastaltech mentioned that he thought that they had built a timer into the 8.1 so that even with a switch, it will only bypass the destination for a few seconds. Has anyone tried this to see if it works? I have the wiring diagram. Would someone with more experience please take a look at this and see what wire I should try. I think it's the violet wire that runs from connector J27 (from the Navigation ECU on page 3) to a relay by connector J18 (by Combination Meter on page 9). If this is right I will give it a try.
Here's the wiring diagram Navigation EWD.pdf
Please help if someone know. Thanks
UtLai
Feb 12, 2015 11:39 PM
azmike
Jan 5, 2010 07:45 AM
