navtool issue big time.
Old Mar 26, 2008 | 01:44 AM
4onenight's Avatar
4onenight
Default navtool issue big time.
well after i bought navtool, i went most electronic and system shops in my area and none ove them said they can do it and whoever said they could asked for the same amount as the navtool. so me and my cousin did it ourselve and it would switch to dvd but wouldnt switch back. after reset and 2nd attempt it wouldnt switch at all.. is anyone here in the so.cal area that may be willing to help me out. at least show me what wiring goes where. please
Old Mar 26, 2008 | 09:07 AM
Lexiss_sc430's Avatar
Lexiss_sc430
did you use Pearlpowers instructions for the install?
https://www.clublexus.com/forums/sho...avtool+install
If you still can't figure it out call me up and I'll try to help you out as best as I can.
Old Mar 26, 2008 | 09:20 PM
da-bizket's Avatar
da-bizket
I had problems with my navtool until I soldered the wires. The wires are so thin that the crimp / insulation displacement fasteners weren't working.
Mark
(da-bizket)
Old Mar 27, 2008 | 06:05 AM
Habious's Avatar
Habious
I also had to solder the wire for the reverse switch. And, had a really hard time with the wires for the input-select switch...which sounds like where your issue is. I'm pretty sure that "open" is the secondary input and "closed" puts you back to factory Nav so, if you've got a loose connection with those wires, you wouldn't be able to get back to factory Nav.
Old Mar 29, 2008 | 03:50 AM
4onenight's Avatar
4onenight
Ok I Soldered All Wires To Tell You The Truth And It Worked Perfect, But Once I Was Fishing Out The Switch From The Trunk Through To The Car It Just Died. The Nav Stays On Nav Whether I Flip The Switch Or Not. Only Thing That Works Is The Backup Camera.
jp1guy
GX - 1st Gen (2003-2009)
May 14, 2017 02:02 PM
NourasElia
Mar 31, 2017 11:53 PM
snboarder8
12
Mar 13, 2003 03:14 PM
