XM radio interface
Old Feb 18, 2002 | 06:16 AM
gadgetguy's Avatar
gadgetguy
Question XM radio interface
I've been trying to install the GEXFM903 Pioneer FM modulated xm radio unit into my LS430 with the Mark Levenson system. This Pioneer unit must interface with the FM antenna connection. The antenna connector at the tuner pack is a Molex connector of some sort that houses both the FM antenna connection and the diversity antenna connection. Does anyone know if there is an adaptor available that would allow a standard Motorola antenna connection to interface with the Molex connector? Any suggestions would be helpful.
Old Feb 20, 2002 | 09:49 AM
LS007's Avatar
LS007
You could T-tap a female motorola plug to the wires from the molex like connector, but if your traveling near a radio station that has a strong signal near the frequency of your FM modulator, you could hear it along with your XM... not so good.
Or better you could simply cut the two antenna wires going into the Molex plug and put in a male and female motorola plug. Your GEXFM903 would then plug right in. If you ever remove the GEX simply plug the motorola plugs together.
P.S. Let me know if you need help identifying the antenna wires, I have the EWD for the LS430. It shouldn't be a problem as one wire will be ground and that is the antenna shield.
Old Feb 20, 2002 | 02:25 PM
enginyr's Avatar
enginyr
Banned
Is XM any good?
theazz
Oct 28, 2019 01:16 AM
maudieinto
Jun 4, 2019 07:09 PM
Paul B
Mar 9, 2007 11:52 PM
Flufferiou
Oct 6, 2006 07:34 AM
DaveJ
Aug 12, 2005 07:27 AM
