Mark levinson Stereo problem!! gs430
today I was drving along and then all sudden my stereo stop playing music...nav screen still works ...but zero sound
then when I turn the car off...and turn it on..i get music again..for 3 seconds then it cuts out.
bad amp? this is weird...when my amp went bad 2 years ago...it popped etc..
this is all quiet
any body please help!
this is all quiet
bad wiring -- i.e. remote wire...
on a different but slightly similar note mine did this once last summer (only the radio would play--- no cd) after i put a bunch of stuff in my glove box and shut it,,, after about 30 mins of getting pissed off i realized that there was to much stuff in the glove box and it was putting to much pressure (pushing up) on the cd changer so i moved some stuff and problem solved.
sometimes it something completely unexpected that fixes the problem.
_____________
i have no sig..... i have no sig.....
_____________
ML Amp.
The internal design of the amp is "**** poor" to say the least. One very small fan is used to cool the entire assembly. Even though they TRY to heat sink it, the installation is usually kept in a small area that gets very very little airflow.
The ML amps have had more problems than any other audio name in history for any automobiles from Lexus. Same with the ML speakers. They tend to blow out quite often.
That's what you get for "good marketing". Hype the name "Mark Levinson" but not back it up with the same build quality as their home gear.
sorry to bring back older threads but i have the exact same problem.
to OP - i know you replaced everything to Alpine, but did you keep the Nav screen? if you got any pics, i'd appreciate them.
Today i was told that i can't replace the ML amp with a 5ch aftermarket amp. Only to get a new HU and speakers/amps. Am i being BSed or thats how it goes?
you can do it with a 5 channel, but it sounds way better with everyting
yes i kept the nav screen, and sould all the mark levinson stuff
i went wiht a 4 channel amp, and a mono amp for the subs...then went with componants up front and 6.5's in the rear...and let me tellyou it blows the ML stuff away..
plus after i sold all my old ML stuff...it was a deal!!!
Can someone tell me if replacing just the amplifier with a 5ch aftermarket(instead of ML amp) is possible? MOST people tell me NO but in a few threads(like this one) i've found that it was done. I've contacted all of them and no response. SOMEONE SHINE SOME LIGHT ON THIS please! driving in silence is a pain.
Percy - when I took out the ML sub and speakers i was amazed how flimzy and cheaply made it felt. I wonder if ML stuff in new LS's and LX's any better?
That's funny, that's the same thing KIM CATTRALL said...
