Is there a hole in drivers firewall?
Old May 15, 2008 | 05:35 PM
Dx3's Avatar
Dx3
Default Is there a hole in drivers firewall?
Guys,
This question has been asked with mixed answers.
Is there a hole you can run wires through on the passenger firewall from the engine bay through to the passenger footwell?
I know there is in the GS - but not sure if there is in the SC.
So who 100% KNOWS for sure?
Jonny
Old May 15, 2008 | 06:01 PM
scheme56's Avatar
scheme56
yes, there is a hole you can access from the engine bay that is on the driver's side firewall which can be used to run your power wire. i do not know about the passenger side.
Old May 15, 2008 | 06:49 PM
qksl2's Avatar
qksl2
The best place to run wires is under the pass side carpet. There are several gromets.
Ian
Old May 15, 2008 | 06:53 PM
evileagle's Avatar
evileagle
Ian
+1
Old May 15, 2008 | 06:54 PM
bcp_sc300's Avatar
bcp_sc300
Registered User
its on the driver side wheel wall under the fender
Old May 15, 2008 | 07:04 PM
Deceptik1's Avatar
Deceptik1
This location is good because you can easily run the wire up your fender lining and it will come out through the hole to the left of the brake master cylinder.
Old May 15, 2008 | 07:11 PM
scheme56's Avatar
scheme56
i'm trying to remember off the top of my head but i believe you can use a one holes that have an existing wire going thru the driver side firewall underneath or close to the brake reservoir, close to the fender. best way is to rip a small hole then feed an unbent metal hanger through the hole. angle the hanger downwards when feeding it thru the firewall. be sure to remove the carpeting and padding for a clean pass. once the hanger passes through the firewall and other obstacles, tape your wire firmly onto the back end of the hanger then thread the wire through the firewall viola! you're done. the wire will be protected from the metal edges with the existing grommet but you might want to put on a shroud for the rest of the exposed wire.
YODAONE
Sep 7, 2018 09:39 PM
toy4life86
Oct 28, 2008 06:28 PM
USAF_RT
Oct 8, 2007 02:53 PM
bt430
Apr 7, 2007 06:20 AM
DaBling69
May 12, 2006 06:42 AM
