Eclipse AVN 5510 installed in SC300??
Old May 12, 2008 | 01:33 PM
kght_dft's Avatar
kght_dft
Default HELP?!?!? Want to install Eclipse AVN 5510 in SC300 but lost PLEASE HELP?!?!?
Hey, do anyone have a link or pics or just anything that would help me out with the installation of the Eclipse AVN 5510 in a 96 SC300? I need details upon where some of the wires needs to be connected to. Oh yeah, I forgot. Does anyone know what is the MAX size speakers that I can use for the sc300. I believe the stock speakers are 4", so can I go BIGGER?? Please HELP! HELP! Thanks Guys/Gurls!!
Old May 18, 2008 | 11:59 PM
kght_dft's Avatar
kght_dft
AnyONE?!?!?! HELP?!?!
Old May 22, 2008 | 07:41 PM
tresevSC3's Avatar
tresevSC3
i dont have any pics of my install yet, which system do you have the pioneer or nak i can get you the wire colors and hwere to hook them up, and you can fit 6.5 all the way around you just have to make plates in the front or buy the plates premade on ebay and depending on the speaker possibly spacers in the back
Old May 23, 2008 | 07:32 PM
swaqqa's Avatar
swaqqa
Get the spacers on ebay if you wanna fit 6.5" in the fronts, but the Rears will have to be custom done to fit 6.5"
Old May 23, 2008 | 10:50 PM
kratos's Avatar
kratos
I don't recommend these spacers. The grille is only so big so running larger speakers will only be muffled. Run 5.25's after you dremel the mounting hole out. Much better sound.
As for wiring its not as simple as just buying a harness. You will need to either bypass the amp and run speaker wires directly to the speakers or turn your low level outputs into RCAs to plug into the deck - its a bit complicated and a pain in the ***.
Please do a search on this subject!
Edit: My old AVN-5510:
1JZSc300
Dec 5, 2010 11:28 AM
ypv123
May 18, 2010 07:49 PM
jtwopark
Nov 27, 2008 01:20 PM
Toshima
Nov 27, 2006 04:30 PM
gsnav
12
Jan 1, 2002 11:16 PM
