Need help with wiring system setup
Old Mar 30, 2008 | 08:48 PM
Toshima's Avatar
Toshima
Default Need help with wiring system setup
I made a picture in mspaint on how I have my system setup right now. I am about to get a 2 Farad Digital Capacitor. I was wondering were it would go. Im guessing after the second battery, and have all my amps power wires going to it right? Also I was wondering If I have to many fuse. Do I only need one big fuse? Also right now every thing is 4ga, but would I gain anything by making the power and ground wire that goes from battery to battery, and then battery to cap a 0ga. I dont have any problems with the system right now amps are turned down to 1/4 there power. I turned them up to 1/2 to 3/4 there power and I blew the 2 fuse that went to the amps that power the subs. Any help would be great. Thanks
Old Mar 30, 2008 | 09:40 PM
rgarjr's Avatar
rgarjr
Caps are used mainly in subwoofer amps because they draw the most amount of power when the woofer is pounding a deep low audio note.
Old Mar 31, 2008 | 05:58 PM
Toshima's Avatar
Toshima
Well i have 2 mono amps that are wired up to one sub each. So how should I wire it.
Old Mar 31, 2008 | 06:19 PM
88supramki's Avatar
88supramki
why are you doing 2 batteries?
are you really running THAT much power?
Old Mar 31, 2008 | 07:28 PM
Toshima's Avatar
Toshima
I have 1800 watts rms and 3300 watts max. My other battery in the trunk is a small kinetic HC600. Even with both batters it makes my lights dim. So I got a good deal on a massive 2 farad cap so I picked it up to see if it helps any. So should I install it to the 2 amps that go to the sub's there mono block amps.
Old Apr 1, 2008 | 01:15 AM
red04r1's Avatar
red04r1
maybe a 5-10 or 20 farad might be better then 2?
harold2011
Sep 8, 2017 10:54 AM
aristonic
Sep 2, 2015 01:50 PM
sgmstr
Jan 10, 2014 06:38 PM
RuffinoJ
Nov 14, 2013 07:33 AM
TurboES300
Nov 13, 2006 03:22 PM
