Car no power!!!! Helpp!!!!!!!!!!!
Old Nov 13, 2013 | 03:35 PM
RuffinoJ's Avatar
RuffinoJ
Exclamation Car no power!!!! Helpp!!!!!!!!!!!
over the last couple months i have lost power to my car a couple times! you will be fine with power than nothing! i used to just wiggle the terminal on the positive side of battery and it would work! yesterday it wouldnt work so my grandpa came over and we got it to work! i drove it around all day today and i got a new terminal! i got home and switched the terminal and now i cant get power to the car no matter what i do! the battery is full charged and good! you check all the lines from the battery and they are good! all the fuses are good! but the car its self wont get power! the battery sense power to the fuse panel! how do i get power to my car when everything gets power internally but my car wont get power? from battery to starter theres power! from battery to fuse panel theres power! the fuses are good! any ideas why my car wont get power when everything else has power?
Old Nov 13, 2013 | 03:42 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Did you check the Alternator! Also check for adequate grounding! It doesn't hurt to get a couple extra grounding wires and ground them to the chassis/frame/engine block! GL! !!!!!
Old Nov 13, 2013 | 04:39 PM
SCstone's Avatar
SCstone
^^x2 alternator/grounding!!!
you have radio and stuff but when you start the car you have no power!?! something is loose or alternator/starter is going out! longshot but battery might need distiled water or not enough amps!
Old Nov 13, 2013 | 04:53 PM
RuffinoJ's Avatar
RuffinoJ
I have absolutely no power whats so ever. The altenator was just replaced not to long ago.
How do i check the grouding?
Old Nov 14, 2013 | 07:33 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
There should be a ground from the battery terminal to the engine block/chassis/frame. Wouldnt hurt to grab another ground from the block to the batt. Worst comes to worse, the starter siezed...?
harold2011
Sep 8, 2017 10:54 AM
UGAALF
Dec 4, 2015 01:20 PM
sgmstr
Jan 10, 2014 06:38 PM
Teahupoo
IS - 1st Gen (2001-2005)
Dec 18, 2011 06:55 AM
DB S600
Sep 4, 2004 03:19 PM
