RX300 and Car Pc Help Please
Old Jun 9, 2007 | 06:41 PM
swj123's Avatar
swj123
Default RX300 and Car Pc Help Please
Hello All, I am needing some advise on something. I have been reading and reading to no avail. I have done the Ipod mod on my RX300. I cut into the wires near the external cd changer and put in a 4 pole relay like I have seen posted on the forums. When I plug my Ipod in it sounds fantastic. Near cd quality. No noise or hum when paused. Pefect. But when I try to plug the aux input into my Car Pc's internal sound card there is noise and it sounds very bad. I understand it's because the RX300 is balanced audio and the Car Pc is unbalanced audio. What I need is a device to put between the Aux in and the Car Pc so the audio is matched perfectly. So I am asking for suggestions for the best device to buy. (or Build)
For your info I have the Mini-ITX Epia M10000 with Xenarc 8" touchscreen
running Roadrunner. Thanks, Mike
Old Jun 9, 2007 | 09:49 PM
Tranman's Avatar
Tranman
Registered User
Well, the humming is because there is a ground loop when you connect the CarPC to your Aux input...you have two options here.
One, try to ground the CarPC and related components to a single spot in hopes of getting rid of the humming.
Two, just put a ground loop isolator (Radio Shack) in between the AUX and CarPC output and that'll be the end of that. The only issue with using a ground loop isolator is the fact that it reduces the range of sound frequency...but it's not a big deal unless you are one of those geeky audiophiles...
whitels
RX - 1st Gen (1999-2003)
21
Sep 25, 2010 08:28 PM
maxbreaker
Apr 18, 2008 07:34 AM
swj123
Jun 7, 2007 01:46 PM
VSsc400
Jun 18, 2004 07:15 PM
