Battery and car audio
Old May 18, 2007 | 05:24 PM
wiliefeliz's Avatar
wiliefeliz
Default Battery and car audio
Hello,
My name is Will, this is my first post, and I've been a 98 GS400 owner for a little more than a year. I just got my subs put in today. They are 2-12in Kicker Solo Barics and two amps, Kicker ZR360. I know the smart thing to do is probably put some caps so it wouldn't drain the battery fast, but has anyone just straight up run their system from their battery? Thanks in advance for any comments.
Old May 18, 2007 | 06:18 PM
88supramki's Avatar
88supramki
you should be fine, just don't run the stereo for very long (if at all) without your car running
Old May 19, 2007 | 01:00 AM
wiliefeliz's Avatar
wiliefeliz
Would it be wise to run some sort of cap? or any other alternative so I won't ruin the alternator or drain the battery so quickly?
Old May 19, 2007 | 04:50 AM
MJHSC400's Avatar
MJHSC400
Extra battery in trunk= Like a yellow top-- I think a deep cycle would get you what you want also, but they only last 2 yrs or so-- The reserve on a deep cycle is awesome-- I'm just not sure how a deep cycle would react to being kept nearly fully charged all the time-- A yellow top or a half-size yellow top might be best-
Old May 24, 2007 | 02:51 PM
erftimmeh's Avatar
erftimmeh
Default same problem
hey i have the same problem how do u guys know if its the alternator went bad or whats draining the battery.
timmy
Old May 24, 2007 | 04:57 PM
MJHSC400's Avatar
MJHSC400
have your alternator and battery tested at autozone-- test the alt first with the handheld load tester-- easiest way and doesn't require removal of the alt from the car just to test it--
A bad alternator can kill a battery too-- so if the alt's bad have the battery load tested as well--
KoSC300
Hybrid Technology
May 9, 2016 08:07 AM
LS430Lexus
Jan 11, 2013 05:27 AM
SlickRSM
Jun 25, 2012 02:06 PM
Ishinc
13
Jan 31, 2006 05:33 PM
lightwave76
Jan 26, 2003 03:11 AM
