Stereo Problems
Old Apr 18, 2007 | 07:27 PM
Ckroush's Avatar
Ckroush
Default Stereo Problems
I have been having problems with the display on my dash unit. The text will jumble into jibberish every once in awhile and it can usually be solved by turning it off and then back on.
I also have a problem with presets 4-6. It doesn't matter what station is stored in the memory. If I select one of those presets, the music will cut off every 5 seconds for just a split second and then come back. If I scan up or down and then come back to the station it will fix the problem.
However, even if I have scanned up or down and came back to keep it from cutting out.... when i get back into the car and turn the radio on, if it's on presets 4-6... it will still cut out until I do my scanning trick
Old Apr 27, 2007 | 01:49 AM
Ckroush's Avatar
Ckroush
I was trying to be as descriptive as possible, but it may have just sounded confusing. Presets 4-6 cut on and off, while 1-3 have a lot of static. The text on the screen is jibberish as seen above.
Do you think there is a short somewhere? Or do you think that maybe the antenna is pinched or has a loose connection?
Old Apr 27, 2007 | 01:51 AM
dung0981's Avatar
dung0981
CL Folding 10,000
disconnect the battery power and put it back. I may fixed the problem
xuzhili23
Aug 28, 2016 07:14 PM
DarylS2001
RX - 3rd Gen (2010-2015)
Dec 7, 2011 07:22 PM
Metmismeth
Jun 5, 2011 05:06 PM
VKBSC3
Mar 10, 2010 10:44 AM
