Pioneer Z1 and GS2
Old Jan 23, 2007 | 02:01 AM
dung0981's Avatar
dung0981
CL Folding 10,000
Default Pioneer Z1 and GS2
Hi All
Anyone have Z1 installed in GS2. i need help with the Pink wire of Z1( car speed signal input) Where do we connect this wire to our gs2??? whats color of this wire? Where is it located?
Thanks in advance
Old Jan 23, 2007 | 07:14 PM
gapxguy's Avatar
gapxguy
Isn't the pink wire the reverse wire? The VSS is purple I think...
Old Jan 23, 2007 | 08:29 PM
dung0981's Avatar
dung0981
CL Folding 10,000
The reversegear signal in put is violet/white. I am looking for the vehical's speed detection... Please help me . I need it bad..
Thanks in advance
Old Jan 24, 2007 | 01:00 AM
gapxguy's Avatar
gapxguy
I believe it's the green wire behind the cluster. I installed my Z1 without it and everything works fine in 3D mode. I guess it's for when the car doesn't have satellite signal.
Old Jan 24, 2007 | 09:48 PM
dung0981's Avatar
dung0981
CL Folding 10,000
Without that wire the navigation work good but when the signal lost this wire help locate the car position on the map.
I found it, Blue/yellow for the VSS coming from the transmission
Did you bypass yr Z1?
Thanks
Doan
Old Dec 2, 2007 | 06:39 AM
VirtuousE's Avatar
VirtuousE
BTW where is the reverse wire located...I was told it was the 20 pin plug...where is this plug exactly located under the drivers kick panel
pga88
Dec 15, 2010 08:51 PM
Infamous 1
Jan 8, 2009 07:11 PM
miraluna
Jun 11, 2007 12:05 AM
tige1975
GS - 1st Gen (1993-1997)
Jan 25, 2003 08:36 PM
