XM/Sirius Radio... PLEASE VERIFY!!
Old Sep 1, 2006 | 03:22 PM
FLIPPU's Avatar
FLIPPU
Default XM/Sirius Radio... PLEASE VERIFY!!
I have an 04 LS430 with either XM or Sirius.. I have the SAT/AM button on my ML System..
The system is hooked up because when I press the button, I get the SAT display on my NAV Screen, but it is only the DEMO version as I did not pay for the subscription.
My question is,
If I have this SAT/AM button on my dash, this means that I have a module and/or tuner/brain in my car somewhere and it is plugged into my ML AMP somehow since I get sound out of it.
Is this brain plugged in directly into my ML AMP or does it use some sort of FM Modulator?
If it is indeed a direct plug to my amp, can I somehow TAP into this source and use it to get sound out of say... Play Station, Xbox, DVD..etc???
Thanks
Mike
Old Sep 2, 2006 | 09:34 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
You're playing with fire. You would need special adapters that are not necessarily made yet, or a lot of electronics experience.
You may be able to use a Peripheral, Soundgate, VaisTech, or Blitzsafe aux input adapter to do what you want, if one of them makes one for your vehicle model/year. Check their websites, and/or call them.
Old Sep 3, 2006 | 08:28 PM
psp's Avatar
psp
Hi Flippu,
1. The Sirius/XM unit is either connected to the head unit or the ML amp (but I am going to guess the head unit since you see it on the Nav - I could be wrong). I am fairly certain that it is not an FM modulator.
2. If you had an 07 ES you would have a 2.5mm jack in your center console to use with a headphone output from almost any device, but you do not. I do not think that there is an input jack on the satellite radio; they use some kind of nonstandard connector that is used for power, sound, and control. As engin_ear stated there are units, such as the VaisTech (which I use) for my iPod, that also has a pair of RCA inputs for an "aux" connection.
Old Sep 3, 2006 | 08:41 PM
FLIPPU's Avatar
FLIPPU
i traced down the antenna and it is plugged into a box/module (under the rear deck) that has an 8 connector plug which is connected to the ML amp...
hmmmmm...ideas...lol
mike
shrikelex
Jun 18, 2014 06:22 AM
irishbrahm
Jun 30, 2013 04:54 AM
460LSinTN
Jun 12, 2012 04:10 AM
mjnoles1
Jan 7, 2005 12:40 AM
Scott Johnston
Nov 2, 2001 02:01 PM
