Stock subwoofer diameter?
Old May 14, 2006 | 03:54 PM
deruvian's Avatar
deruvian
Default Stock subwoofer diameter?
I've done a bit of searching to attempt to find the diameter of the stock subwoofer, but I've found conflicting information. I've seen both 8" and 10" as the supposed size, and I just want to clear this up. When I bought the car, it came with a RF 10" sub and a SoundStream amp (in a box in the trunk, looks to be about 1.5 cf). I want to move this into the rear deck if possible.
Thanks for the help.
Old May 14, 2006 | 04:05 PM
vipsoarer's Avatar
vipsoarer
you can move it to the deck if it is 1. a free air designed sub. 2. its mounting depth is shallow enough not to interfere with the gas tank and 3 if you dont mind that back deck rattling.
oh and the size of the stock sub all depended on the options you got...some received an 8" stock while others got a 10"
Old May 14, 2006 | 04:08 PM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
I have a 10 inch kicker SUB and it fits but almost touches the fuel tank...I think an 8 inch sub would fit the best...Here is a pic
Old May 14, 2006 | 04:09 PM
jibbby's Avatar
jibbby
OOOps wrong pic...
Old May 14, 2006 | 04:19 PM
lfrers's Avatar
lfrers
Default .
Stock is a 10" Make sure you buy a free floating sub or an enclosureless sub. One that does not need to be installed in an enclosure to sound or operate properly. Also make sure the height of the speaker is OK. Too tall and you wont be able to get the grill to fit right after you install the speaker because of the gas tank.
Old May 14, 2006 | 04:36 PM
sonyman's Avatar
sonyman
The only cars with 8" subs are those with the early base model Pioneer cassette-only stereos. Both the Pioneer CD and Nakamichi setups have 10" subs.
Scott
Old May 15, 2006 | 09:05 AM
deruvian's Avatar
deruvian
I can't believe I spaced out on the fact that I'll need an enclosureless sub.
Anyhow, sounds like it'd be more trouble than it's worth. I'll just look into installing some better components w/ an amp. I've got the typical Pioneer system, so there's nothing special about my setup.
Thanks fellas.
Jewel707
Oct 28, 2020 01:45 PM
CheVelleSS
Feb 8, 2011 10:26 PM
t70 supra
Feb 26, 2009 05:51 PM
questnyc
Jun 22, 2008 10:08 PM
jb86
15
Apr 25, 2006 08:09 PM
