How do you repin a plug?
Old Apr 24, 2006 | 08:34 AM
Dx3's Avatar
Dx3
Default How do you repin a plug?
Guys,
Can anyone explain or show me a link that explains how you repin a plug??
Thanks,
Jonny
Old Apr 24, 2006 | 10:11 AM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
What kind of plug?
Percy
Old Apr 24, 2006 | 10:18 AM
Dx3's Avatar
Dx3
Originally Posted by Percy
What kind of plug?
Percy
It is the plug for my MAF. One of the wires came loose on it. Lexus doesn't sell plugs, trying to charge me $2000 for a new harness
Jonny
Old Apr 24, 2006 | 10:22 AM
Percy's Avatar
Percy
25 Year Member
Can you take a picture of the condition of the plug? Want to see what's damaged....
Percy
Old Apr 24, 2006 | 10:25 AM
Dx3's Avatar
Dx3
Percy
Percy,
There is just one wire pulled out of it - apart from that it is completely fine. I am at work so I don't have any pictures.
Jonny
Old Apr 24, 2006 | 09:17 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
This can be complicated. Usually pins push into a connector and a small metal tab on the pin snaps past a stop in the plastic of the connector. To replace, you'd need to know the manufacturer, most likely Japanese, and then be able to buy the correct pins for that connector type. You may also need the correct crimping tool for the particular pin type.
To remove a pin, you would push down the metal tab that holds it in, then pull it out. Very easy to screw things up if you lack experience. You may be able to fix the *connection* without having to fix the connector.
Yeah, might be good to have a picture (a close-up) of the connector to see if any of us can recognize it.....
Jerry
Old Apr 24, 2006 | 10:16 PM
Percy's Avatar
Percy
25 Year Member
Some of the automotive engine connectors are pretty much sealed with epoxy or molded into place. Headaches and nightmares. When they meant weatherproof connector, they meant it. That's probably worst case scenario. Still need to look at a pic when you get a chance.
Percy
DEREKC
IS - 1st Gen (2001-2005)
May 6, 2019 04:21 AM
Lexscme
Oct 17, 2009 07:04 PM
1sxyrxy
Jul 8, 2008 09:44 AM
mcelligott
Apr 29, 2002 02:57 PM
MrHorse
Performance
Jan 24, 2002 06:44 PM
