Just Bass (sc300)
I have a left over amp and sub in a box. I don't want to spend more money on other parts and what not as i spend enough on everything else and i simply just want more bass. I've looked around, but haven't really found anything.
I was wondering is there anyway i can just add these parts on like somehow just using the stock wiring and replacing the old sub amp with my aftermarket and connect that to my sub?
any help would be appreciated. thanks.
ya. the easiest way is to do this: You need to use a adjustible hi-lo or line converter by cutting and redirecting the sub output wire to it. Then, you must turn the sensitivity down on this line converter ( as it is coming from a amplified source. Get RCAs, install your amp, get your remote wire from the ACC in the front or tap a wire that is 12v activated only when you start your car.
hook ur sub up to ur amp and ur done. Hardest part is finding a 12v line that will act as your turn-on. using a T-tap clip is probably reccomended.
Frankdorn
May 28, 2010 10:26 AM
qha_vn
Jul 21, 2009 04:14 AM
