Antenna Problems
Old Dec 13, 2005 | 07:09 AM
92LexusSC4's Avatar
92LexusSC4
Default Antenna Problems
Yes, I've searched the forums before posting this. The only solution that sounded reasonable is that I need to replace my antenna mast. Heres what happens, when I turn my radio on it went half way up and started making this horrible noise and stopped. The antenna went only half way up then the radio worked like usual. Once I turned the radio off, I could hear the motor trying to recontract the antenna back into "off mode" but the antenna stayed in the same postion (half way). I'm not sure what the problem is but I don't think its the motor seems how i can still hear it when I try to turn the radio on and off. Please help. Thanks in advance!
-Dave
92 Lexus SC400
Old Dec 13, 2005 | 07:42 AM
salimshah's Avatar
salimshah
25 Year Member
Dave:
The mast travel is not smooth and it could be due to kink/bend, lack of lubrication or even broken teeth in the gears.
I would suggest replacing the mast.
Salim
Old Dec 13, 2005 | 08:46 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
The cable that connects the mast to the motor has either snapped or stripped the gears. Replacing the mast will fix the problem. I happen to have the same issue! Just haven't gotten around to repairing it yet. TOO COLD!!!
Old Dec 14, 2005 | 01:06 PM
92LexusSC4's Avatar
92LexusSC4
Thanks guys for the help! I guess I can add that to my x-mas list. I appreciate the replies
-Dave
rclab1
May 3, 2013 12:30 PM
1995LS400
Dec 4, 2007 06:43 AM
Lexson
Aug 29, 2002 02:11 PM
