help with amp hum on custom install rx
Old Jul 15, 2001 | 11:21 PM
mikebyron
Guest
Posts: n/a
Angry
I had a 12" alumapro and a memphis amp installed in my rx300 - very loud and solid. only problem - the installer claims he could not get rid of AC hum and could not get a good "stereo on" voltage. (the only line he could find would not deliver enough amps to switch on the amplifier)
Result - when at low volumes or off, the amp whines like a 6 month old - constantly !!! arg - very embarrasing to take someone in your lexus and hear a squealing while driving.
does anyone have similiar experience or suggestions for a turn on when stereo on - or voltage isolation ideas?
Old Jul 16, 2001 | 06:47 PM
importtoys's Avatar
importtoys
get a line driver,wire the amp remote to the power antenna and turn the gains down on the amp.. good luck
Old Jul 16, 2001 | 08:31 PM
mikebyron
Guest
Posts: n/a
Default line driver? what about cd..
sorry, I don't know what a line driver is. they did take line level inputs from under the dash (vs off the amp).
Also, If I take the power antenna trigger, won't the amp only turn on with the radio? like no cd?
Old Jul 17, 2001 | 11:35 AM
importtoys's Avatar
importtoys
Line drivers Boost up the voltage signal from the head unit to the amplifier giving optimum power and effeciency.. I'll send you a PM later today to try and help you out
aporozco
Oct 14, 2010 11:31 PM
mkaye
Dec 4, 2009 01:51 PM
stuching
Aug 6, 2008 08:48 PM
ginessgold
Aug 24, 2003 04:41 PM
