Does anyone know how to take the key apart to replace the battery? I took the screw out but it seem that the two half stuck together by a clip in the back of the key. Which way does it slide out? I don't want to break it.
Thanks,
Thanks,
I just did it myself 5 minutes ago. The plastic is thin, so it seems scary, but just continue to pry the two halves apart. At the same time, slide the half with the screw hole backwards, away from the metal area (highly technical terminology here
). The side with the screw hole is not connected to the metal. They two halves seem to stick together due to grime. Good luck!
). The side with the screw hole is not connected to the metal. They two halves seem to stick together due to grime. Good luck! Thanks Jon,
Did the same as you descirped last week. Thought that the plastic clip will broke off but it didn't
