Enabling nav menus while moving w/ no cables on 2001-2005 Lexus
Old Aug 7, 2005 | 09:16 PM
Radius9's Avatar
Radius9
Default Enabling nav menus while moving w/ no cables on 2001-2005 Lexus
I saw the other posts on how to get to the system menu on the newer nav systems and turn on the override that lets you enter nav destinations while moving. After playing around with my nav system on my 2001 GS430, I figured out how to do the same thing. Press the menu button, then choose system option. Then press the top left of the screen, then the bottom left of the screen, then the top left again, then the bottom left again, then finally touch the bottom right of the screen. It will bring up a system menu. Choose the override button, then hit back. If you do this while moving, you won't be able to edit until you stop the first time. If you are stopped when you do this, then you can continue to edit while moving. You can do some other crazy stuff as well, I copied my DVD from my nav system and I am going to see if I can figure out how the thing works to modify it, so that this is enabled permanently, but until then, here you go....
Old Aug 8, 2005 | 08:45 AM
IS0LD0UT's Avatar
IS0LD0UT
Nice job!!!!! I can't wait to try this over lunch.
Old Aug 8, 2005 | 09:03 AM
jazba's Avatar
jazba
forget lunch, imma go try it now. Or atleast attempt it on my rx.
Old Aug 8, 2005 | 10:09 AM
rcodey's Avatar
rcodey
On my 2004 Rx-330, I touched the DVD button from the Menu screen and then followed the directions from above.The system menu popped up with the Override button.
Old Aug 8, 2005 | 10:30 AM
rgarjr's Avatar
rgarjr
Anyone know if you can do it on a 98 NAV
Old Aug 8, 2005 | 11:10 AM
jazba's Avatar
jazba
SUCCESS ON THE RX. thats hottttt
Old Aug 8, 2005 | 12:39 PM
jp430's Avatar
jp430
Default Thats cool
I just did it. I feel like a hacker!!! Is there a way to get control of N. Koreas nuclar weapons through satalite??
Old Aug 8, 2005 | 03:49 PM
Neo's Avatar
Neo
The One
Nice find. I think this is going to be a popular thread.
Old Aug 8, 2005 | 09:11 PM
Booyah's Avatar
Booyah
Glad you found this for the 04's!
I got to the override button on mine like stated but it would not hightlight green like the other button did?? Do I just press it once and now Im in override and can enter the destination while driving
Or is the Override button supposed to turn green?
Old Aug 9, 2005 | 08:02 AM
IS0LD0UT's Avatar
IS0LD0UT
IT WORKS!!! So if the override of the features is controled in software, then we should be able to patch the DVD and get it disabled permantly.
Old Aug 9, 2005 | 10:50 AM
rcodey's Avatar
rcodey
Keep pressing the overiride button for about 5 seconds,then it will turn green and beep.
Old Aug 10, 2005 | 09:10 PM
gs4to4's Avatar
gs4to4
It works on the 2001-2003 LS430! This is really a great find. Thanks to the person that started this! This trick belongs in all of the forums as a sticky.
Old Aug 15, 2005 | 08:39 AM
tgergen's Avatar
tgergen
Tried it on my 04 GX470.....no dice. I don't have "system option" on the menu screen. D'OH!
Old Aug 15, 2005 | 10:16 AM
gs4to4's Avatar
gs4to4
Hi,
This should definetely work with all Lexus Models. Please do a little research using the "Search" option or ask someone in the GX forum.
Old Aug 15, 2005 | 10:17 AM
tgergen's Avatar
tgergen
I did do a search and found all sorts of conflicting info. I actually work for a living and don't have hours to spend, searching through 500 fricken posts, to find that one gold nugget. I though I would ask here...sorry.
