Replace stocks
Old Jul 11, 2005 | 03:52 PM
Rockero28's Avatar
Rockero28
Exclamation Replace stocks
Well, i decided I want to replace the stock door speakers and tweeters.. Anyone know the sizes in a 99 GS300 Pioneer equipped GS300? Already did the Kicker free air, so now I just need to get the rest up to par....
Thanks,
Rock
Old Jul 11, 2005 | 05:29 PM
rgarjr's Avatar
rgarjr
Stock doors are tiny 4" speakers.
Old Jul 11, 2005 | 05:30 PM
Rockero28's Avatar
Rockero28
Default speakers
So all 4 doors are 4"??? What about the tweeters??
Rock
Old Jul 11, 2005 | 05:45 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
Tweeters are 3/4 or 1", in the corner of the A-pillars. If you plan on replacing them, you can fit many aftermarket tweeters in there, but you'll need to take some good measurements and maybe make new mounting brackets to make sure the fit is correct. The tweeter dome cannot hit the back of the grille, or it will distort, and possibly abrade.
Old Jul 11, 2005 | 06:27 PM
Rockero28's Avatar
Rockero28
Default so...
If I want to just doa straight swap.. 3/4 tweeters, will there be any modification needed??? Also, all the doors are 4" right , or can I go to say a 5 or 5.5 without any modification of the fit/location ????
Rock
Old Jul 11, 2005 | 06:47 PM
engin_ear's Avatar
engin_ear
What I would recommend is that you remove a stock tweeter FIRST, then take it to a store with you, or measure it and compare. It is likely you'll need some modification of some sort.
Not likely you can fit anything other than 4" in doors without mod. You may be able to dremel out the plastic enclosure, but I don't recommend it. Most of us have removed plastic enclosure and put in wood or MDF baffles, cut to fit the new speaker.
Old Jul 11, 2005 | 06:54 PM
Rockero28's Avatar
Rockero28
Default ok,
Tansk, I definately do not want to mod... I just want to swap.. one for one.
Thanks,
Rock
Cbb129
Feb 10, 2017 05:57 PM
shvc1991
Aug 30, 2008 11:12 AM
olddog
Dec 1, 2006 08:38 PM
jtgs400
Dec 20, 2005 02:48 PM
