Strange Sound
Old Jul 7, 2005 | 01:22 PM
88supramki's Avatar
88supramki
Default Strange Sound
Hey everyone,
I installed my stereo in my 95 SC300 this past weekend, and everything is going just fine. Except for 1 thing....there is some sort of high pitched hum that will fluctuate higher or lower with the rpms of the motor. The sound is only in one of the rear speakers, I am wondering if it is possibly a bad connection to the amp. I have no idea what could be causing this. Any ideas? Any advice and ideas are greatly appreciated.
Old Jul 7, 2005 | 02:21 PM
3rdelement's Avatar
3rdelement
yes! check your grounds.
you have a GLI Ground Loop Interference, check your ground on both your radio and your amps. I had the same exact problem...i grounded to what i thought was a good source but unfortunately i was wrong.....now my system is killer!
~R
Old Jul 7, 2005 | 03:02 PM
88supramki's Avatar
88supramki
Beauty!
Thanks man, and thanks again on the headlamp cleaning tip.
Was it your deck or your amp that ended up being the issue?
Old Jul 7, 2005 | 03:19 PM
3rdelement's Avatar
3rdelement
for me it was the deck.....
but if your speakers are hooked up through amps and just one speaker is having that problem im guessing its the amp in your case...make sure you are grounded to a clean ground....no rust or pant....and you should be golden.
you are welcome on the lenses~!
cwebb34
Apr 27, 2010 08:34 AM
sliva001
Jun 13, 2007 10:54 AM
olddog
21
May 10, 2007 06:16 PM
groove
Dec 3, 2005 08:52 PM
jbbnet
Nov 1, 2004 09:25 AM
