audiobahn dub200
Old Mar 1, 2005 | 04:03 PM
baddis es's Avatar
baddis es
Default audiobahn dub200
i was looking into subs for my ES and came across the audiobahn's DUB200...there a 12" speaker. they arent bad in price and i know audiobahn makes good speakers, wuts ur guys inputs?
here are the sepcs:
Product Description:
12" Performer subwoofer
Chrome basket
Carbon glass fiber cone
EPDM rubber surround
2" Dual 4 ohm voice coil
Power Handling:
Peak Handling: 2,800 watts approx. Per Pair / 1,400 watts approx. Each Sub
RMS (Continuous): 1,400 watts Per Pair / 700 watts Each Sub
2 ohm or 8 ohm operation
Multi-connect lug lock terminals
120 oz. strontium magnet
Frequency response: 20Hz - 500Hz
Efficiency: 92.7dB
Mounting dpeth: 6-3/8"
Hole cutout: 10-7/8"
Outer diameter: 12-1/8"
Subwoofer Specifications:
Subwoofer Size: 12"
Impedance: 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 2,800 watts approx. Per Pair / 1,400 watts approx. Each Sub
RMS Power Handling: 1,400 watts Per Pair / 700 watts Each Sub
Surround Material: EPDM Rubber
Sealed Box Volume: 0.75 - 1.5 cubic ft.
Ported Box Volume: 1.2 - 3.1 cubic ft.
Sensitivity: 92.7dB
Frequency Response: 20Hz - 500Hz
Top Mount Depth: 6-3/8"
Cutout Diameter: 12" round
Warranty: 1-year SE
Old Mar 1, 2005 | 04:07 PM
/Aerostar\'s Avatar
/Aerostar\
Audiobahn's are solid subs, no doubt. But if you're planning on running just one 12" sub, I would recommend it being a single voice coil (such as the AW122T) so that you can run your amp bridged for more power than running 2 channels (one to each coil)
Old Mar 1, 2005 | 04:37 PM
baddis es's Avatar
baddis es
ohh sorry, i plan on running 2 -12" subs....with a mono-block amp and cap, that should be enough bass to wake up the block!!!
DriftGirl
Jul 19, 2007 08:42 PM
olddog
21
Jun 10, 2007 07:24 PM
hellasboy
Feb 2, 2004 01:32 PM
