remote turn on lead??
Old Nov 22, 2004 | 03:11 PM
white ice's Avatar
white ice
Default remote turn on lead??
ok, so i hooked up my amp today. i am having trouble with the remote turn on lead. i tried wiring it to the OE sub amp; when i used the blue w/ white stripe and nothing. when i tried using the wire that turns into the red wire after the harness. i tried finding the cell phone wire, but had no luck removing the console. it is more than the 2 screws at the back of the console. so i was runnning out of time so i wired it to the cig lighter and it stays on even when the radio is off. the only thing i didnt do get the back off the OE headunit. can any one help me on this matter?
Old Nov 22, 2004 | 05:55 PM
rgarjr's Avatar
rgarjr
Are u running an OEM headunit or aftermarket? If its aftermarket they normally have the remote out wire that you can hook to your amp. If you have an OEM headunit then it might have a turn on wire going to your amp.
Old Nov 23, 2004 | 03:27 AM
white ice's Avatar
white ice
i am using an aftermarket amp. i tried wiring it to the OE amps ACC 12+ but it stays on all the time.
Old Nov 25, 2004 | 01:56 PM
rgarjr's Avatar
rgarjr
I assume you are using the OEM headunit. If you find yourself a 12V acc wire to tap into then it should not stay on all the time. Only when the key is in the ACC or IGN position. Make sure you have everything hooked up right. Maybe the OEM headunit has a 12V switching wire that turns on when the stereo is on, you juse have to get yourself a voltmeter and do some testing.
Old Nov 25, 2004 | 04:08 PM
white ice's Avatar
white ice
i have the ACC remote lead coming the stock 4 channel amp but it gives me a big popping noise and then reverbs when i turn off the HU i get a loud reverb noise. any idears?
krUnALv99
Jul 6, 2012 10:21 PM
94slowbra
Dec 29, 2009 07:45 AM
pwrdbyrice
Aug 19, 2008 09:51 PM
VTLexus
Jun 27, 2008 08:40 PM
hellasboy
Feb 12, 2005 08:59 PM
